I have an Ibico ibiMaster 400 binding machine. i need to get it repaired. where can i send it?
There is a clip that is broken on the underside of the machine. there are 7 of the hole punch bars that wont punch anymore.
  • 329 Answers
SOURCE: Ibico binding machine
I have sold some Ibico machines, depends on the model some are only designed to punch a few sheets such as 6 to 10 booklets. Need the model.
Posted on Jun 24, 2008
  • 359 Answers
SOURCE: Are we able to get
This product is now manufactured by GBC (General Binding Corp, part of Acco) and was replaced by the CombBind C150 - just FYI. The lower-end machines such as this seem to run in the range of $200 USD.
I have never heard of sharpening these "blades", as they are actually punches, and there are likely some 20 small, individual "blades" that are part of the system. You might check with a local dealer or office supply partner, to see if they know of anyone who could or would perform the service and what they might charge for it. I believe that if you could find someone to do it, it would cost more than it would to simply replace the machine. There does not appear to be a way to replace the punch mechanism (die / strip usually) in these models.
An example of a machine with interchangeable dies is located at: http://www.factory-express.com/Binding_Machines/WireBindingMachines/GBC-TL2900/GBC-wirebind-TL2900.html.
Obviously, this is a much higher-level (expensive) machine than the one you have here. But this is an example of the interchange concept, and associated costs.
So, this is a rather long way of saying, and trying to explain why I recommend that, you check with a local dealer perhaps, but plan to replace the machine. If it lasted you this long, the same level of machine should last just as well, and $40 US a year isn't too bad!
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Posted on Jun 30, 2008
checkitright
  • 1362 Answers
SOURCE: Need an instruction manual for
here is the link to the manual
http://safemanuals.com/brand-user-guide-instructions-owner-manual/IBICO
Posted on Jul 18, 2008
techjuli
  • 157 Answers
SOURCE: Lost owners manual for Ibimaster
heres the manual: http://www.acco.co.uk/pdfs/1092.pdf
Posted on Dec 01, 2008
SOURCE: Ibico Binding Machine User Manual/Instructions
Does anyone have instructions for using the ibico hi tech binding system? I lost the instructions on how to attach the wire or combs to the papers. Thank you for your help
Posted on Mar 23, 2009
I have an Ibico ibimaster 400e Binder which is not punching out the holes correctly.
First, clear the waste tray of all hole punchings under the machine, and check the holes where the punchings feed from for any blockages. The worst thing is the clear plastic pages you use for covers, these can block up the holes. So you may need to pick them out of the holes using tweezers.
Then try again. If you have to punch clear covers, then try to do them with just a few pages on both sides so that the plastic sheet isn't the first thing the blades hit.
May 23, 2011 | Office Equipment & Supplies
How do i repair a broken drive coupler?
Unplug the machine. Flip up the controls. Unplug the lid switch connector. Pop the S-clips and tip the case forward. Remove the case. POp the pump clips and tremove the pump. Unplug the motor harness and capacitor. Pop the clips on the motor and set it aside. Remove the coupling end from the transmission and motor. Gently tap the new coupling flush but not up against the tranny (do not bind it). Gently tap the coupling end ontot the motor. Line up the parts and snap the motor back onto the tranny without forcing or binding anything. It should snap on without a great deal of trouble it IS easy to lay the washer on its backside to install the coupling if you is old like I am. Just be careful not to damage anything if you do decide to lay it on its backside and remember the clock is ticking oil will go out of the tranny albeit slowly whilst the washer is on its side. I have 2 videos here. One show how to do it and the other show various styles (older and newer models)
Manual, repair photos, and more videos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 26, 2010 | Kenmore 22932 Top Load Washer
Electric Window move slowly
Your window clips that hold the window in have broken.  You will need to replace these clips in order to fix it right.  The clips you can buy at any audi dealer.  Ask for the most updated ones.  There have been many updated clips.  Audi has been trying to develop better ones for years but they still keep breaking.  Its a very common issue.  Your window will still go up and down but since the clips broke you will have it bind in the track. To get you by for the time been.  Lubricate the window track with some silicon spray.  This will help keep it from binding up until you can do the repair.
May 29, 2009 | 2001 Audi A6
Jun 24, 2008 | Office Equipment & Supplies
Ibico 080s
ACCO Brands Corporation owns General Binding Corporation (GBC). GBC offers products under numerous brands, including Ibico. Ibico's owner's address appears to be in Switzerland
From GBC's sparse Ibico's homepage:
"Contact Us
Where can you buy Ibico Products, fill in your information and the products that you are interested in and we will send you information on the nearest Ibico dealer. "
I'd suggest just going to that page (link here) and filling out the contact info and including the specific information about the model found on this page (namely the product ID num)
.... i could be way off... but it is all i could find on google =)
Jan 04, 2008 | Office Equipment & Supplies
I found the IbiMaster 400 manual!!! The key was finding out that Ibico was sold to General Binding Corp. (GBC). I went to the GBC web site and it linked me to Acco. I called Acco and they promptly sent me an old, scanned PDF of the manual. The very helpful POC at Acco was:
Kaye.Eldridge@acco.com
Jerry Quinn
Sep 28, 2007 | Office Equipment & Supplies
99 people viewed this question
k24674
jasbo
jasbo
