Question about Panasonic CT-36HL43 36" TV
I have a ct-36hl43 thyat when turned on it tries to come on but shuts down and the red power keeps blinking and the only way to stop it from blinking is to pull the wall plug whats the problem??
  • Richard Hammond Dec 12, 2012
    I am not a repairman, I am checking with my brother who is but i am in florida and he is in south carolina I also mdont know about taking the back off the tv I would like a repairman to come to the house but they are to expensive.....
    I must also mention I just replaced the fuse a 6.3amp 250 volts fuse because I coulden,t find a 6.3amp 125 volt that I took out . and it is called a slow blow fuse is this part of the problem ????
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
If you can find the Horizontal output transistor make sure it is not shorted, this set had a issue of repeated shorting of that part after just a few minutes and the cure for that is well known.
To trouble shoot you will need a volt/ohm meter and how to use it, the set if shorted will not always blow the fuse but will go into shutdown to prevent further damage.
Let me know your skill level and if able to use a meter etc or not.
Posted on Dec 10, 2012
4 Suggested Answers
SOURCE: Won't turn off
Juglo, did you ever find a solution to this problem? I just started having this problem.
Posted on Jan 07, 2007
  • 18 Answers
SOURCE: After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Posted on Aug 17, 2007
Orbixx
  • 133 Answers
SOURCE: panasonic ct-36hl43 tv
This is usually down to a safety feature cutting out the Television from harming itself. Or quite possibly a fault that make it turn itself off - it may well be thinking it's receiving the command to turn itself off. Either way, it's impossible to find out without opening it up. A professional repair is the only way, check up on your warranty. You may want to plug it into a different power source, just on the off-chance that it may solve your problem - but don't get your hopes up.
Posted on Sep 07, 2007
My panasonic tv won't turn on just a blinking red light on the front
Your TV is in protection mode. This indicates a fault with the power supply, or other board. First try leaving it unplugged for a while, and trying another outlet.
If none of that works, then it's pretty much toast. Since you've got a CRT, I wouldn't recommend checking the tv out yourself. Take your TV to a local repair shop.
Dec 31, 2010 | Panasonic CT-36HL43 36" TV
WON'T TURN ON
So your saying it blinks for six times then starts over? There is a problem in the system control or the main regulator circuit. Unless you know how to work on solid state printed circuit boards, you really should call out an Authorized Panasonic repair service center to assist you with this repair.
Aug 23, 2007 | Panasonic CT-36HL43 36" TV
Power surge-no picture or sound, just red blinking power light
Any malfunction associated with a blinking redlight usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 13, 2009 | Panasonic CT-36HL43 36" TV
1990 Panasonic 33T86S
the horizontal section is the trouble of your tv, replace the horizontal output transistor
Dec 31, 2007 | Panasonic CT-36HL43 36" TV
My tv dose not turn on
i have a ct-36hl43 it was ac fuse gma 6.3 amp its on the panasonic web site under parts cost a dollar randy vincent ragingbass@comcast.net
Dec 29, 2007 | Panasonic CT-36HL43 36" TV
Panasonic ct-36hl43 tv
Sep 07, 2007 | Panasonic CT-36HL43 36" TV
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
Tv wont turn
replace the AC fuse, a GMA 6.3 amp fuse. I have seen many of these sets where the AC fuse opens for no apparent reason.
Jun 18, 2007 | Panasonic CT-36HL43 36" TV
Won't turn off
it can happen due to overvoltage shutdown circuit. when voltage is too high, tv will shut down. it is possible that this specific model doesnt fit your local electricity network.
Dec 14, 2005 | Panasonic CT-36HL43 36" TV
Panasonic CT-36HL43 36" TV Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
