Question about ViewSonic Vx2250wmled LCD Monitor
Monitor screen goes black for a few seconds then comes back on
Power buttton color goes from blue when turned on to amber like it is in sleep mode but stays on amber even when in use and the screen periodocally goes from normal to a few seconds of black screen then back to on.
bammbammfran
  • 159 Answers
SOURCE: Problem with monitor
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
It sounds like you have bad capacitors on your powerboard or possibly a burned out transistor on the inverter.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
There is a chance one of your bulbs is creating a problem
Should the screen happen to light up all white, then your power board and inverter are okay and the problem may be in the video board.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
If it flashes on then goes off, it's in the power or inverter board.
ebaysbammbammfran
Posted on Oct 12, 2008
BoiseLCD
  • 63 Answers
SOURCE: Monitor will flash windowsxp when I boot up CPU but then goes out
Your monitors backlight is shutting off due to a failed component. The inverter circuit which drives the high current CCFL backlights, has a feedback design so that if there are any problems with the devices along the high current path, the high current will shut off. This way if something got shorted out, it would not sustain or cause any great harm. This is a great feature if you are the "short" in the circuit.
So in actuallity, your monitor is still on, and it's still showing you a picture. You just can't really see it because the light from behind has turned off. If you take a flashlight and put it up close to the screen, you'll see your desktop again!
As to what is causing this, It can be several things.
-A broken or burnt out CCFL
-A bad capacitor in the power supply filter or on the inverter.
-A shorted out IC.
-A mouse has crawled inside your LCD and chewed the CCFL wires. (this usually is accompanied with a high pitched squeeling sound, and/or smoke)
You can send me the entire monitor and I will repair it for $40. You pay shipping costs BOTH ways. Let me know if you're interested and I'll provide you with more information on where to send it.
Thanks
Chris
Boise LCD
sales@boiselcd.com
(208) 891-9117
Posted on Apr 03, 2009
  • 1684 Answers
SOURCE: ViewSonic VG2021m - hard to wake up from sleep
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 22, 2009
Geekman
  • 32281 Answers
SOURCE: Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Posted on Aug 30, 2009
budmrtn
  • 11361 Answers
SOURCE: Viewsonic VA912b. Monitor will only turn on for a
Bad caps in the power supply, common problems. See examples here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20V912B/
Posted on Jan 07, 2010
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
Power is on but after 2-4 seconds display turns off but power is still on where the power light is in blue.it's not in sleep mode where the power color is orange.it just goes back to normal at random...
Without looking at the monitor to confirm this, I suspect you have failing capacitors which power the HT circuit, simply, the power needed to light the display, is leaking to earth, capacitors have lost the ability to store the charge necessary to illuminate the screen, which is why it is working erratically.
You need to get this checked out by a TV technician.
Jul 23, 2011 | Acer Computers & Internet
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
Monitor does not activate when computer is turned on - it goes blank - when you press a button on the front of the monitor it states that the computer is in in sleep mode press any key to activate - the...
May be the problem comes from the Cpu.
Try to see if the cable from the monitor is firmly connected to the cpu.
One thing more may be the vga card is having problem.
Try to test the screen with another Cpu. Or the cpu with another monitor.
The amber mode is normal as the screen is not receiving signal from the cpu.
At times the memory chip also report this problem (no display or sleep mode)
Do hear any beep sound or any other Errors??
OK try this
Cheers Uttam
Jun 12, 2010 | Dell E176FP 17" LCD Monitor
HP 2338H Monitor Goes into Sleep mode and I have to power comput
you meant w2238w , right, you left off the w?
circa 2006 monitor, 11 years old.?
if the monitor fails on 2 PC, the monitor is bad ! ok, do that...
then
push the monitor menu buttton, connected to a running PC.
if the OSD is dead, , (on screen display , menu button front of monitor)
that means the monitor is dead, CCFL tubes are bad.
cold cathod florescient laml tubes all day this old.
the menu button can be in lock mode, hold the button for 10 seconds, and it unlocks
then go in the OSD screens if they work,. and turn off the sleep timer.
this timer is marked in the OSD as power saver,. turn it off.
it is a time clocked feature, and a pain to use on modern PC.
your PC does sleep modes today and never us this timer,inside monitor (default is on, turn it off)
all that is on page32 in your manual,
https://www.manualslib.com/manual/71500/Hp-W2338h.html?page=32#manual
Sep 21, 2017 | HP Computers & Internet
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Stuck in power saver
Try the unlock procedure: With the monitor on press and hold the "MENU button for abot five seconds and see if it resets. If that doesn't work tell me a bit more about the screen - is there any OSD (on screen display) or error messages? Is the power indicator light on? If so, what color is it? Blue indicates that that you may need to turn the brightness and contrast up...\ If it is actually in power save the indicator light will be amber. What color is it? If the light is amber and all the connections to the computer are correct and it still won't come-up then it's an internal problem and the protect circuit may be keeping the screen from lighting. Good luck... And let me know. Bill
Jun 07, 2007 | LG L1722P 19" LCD Monitor
ViewSonic Vx2250wmled LCD Monitor Logo
48 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
