Question about LG Dryers
Dryer LG RC7020A1 runnig water bellow
Dryer LG RC7020A1 running water
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: my dryer LG RC7020A1 running water bellow
Someone is going to have to Look inside to see where that is coming from--maybe a task for someone who is a pro as sooner or later something serious may happen, water and electricity do not mix well.
Posted on Dec 10, 2012
Water leaking from the door of my washer
Either the door is damaged or not properly aligned or tightened or the bellows that the door contacts when closed is damaged. Check to see if the door is loose.Carefully inspect the bellows for rips or holes in the rubber. Many times pointed or sharp items are washed in pockets of clothes they end up tearing or puncturing the bottom of the bellows causing the front to leak water.
Aug 01, 2014 | Whirlpool 4.1 Cu. Ft. Dueta Steam...
My dryer LG RC7020A1 running water bellow
Dec 10, 2012 | Dryers
My lg washer/steamer wd14756sd has the ae code on display. what does this mean?
Code AE is a water leak. There is a float sensor in the base of the machine for this. The likely fault is the lower bellows drain hose as they are convoluted and this catches women's hair pins...the machine vibrations and water in turn rust these which pierce the hose. Hose bellows part number for LG WD14756SD is 4738ER1008A. Be careful for other machines the numbers/parts differ.
Unfortunately it's tight room to replace the hose but it can be done.
Jan 16, 2011 | LG Washing Machines
Leaks water on rinse cycle thru upper vent
Are you referring to the vent on the back of the machine? If your leaking water, you need to replace or install some new mushroom valves. These mushroom valves, go in both bellows on the top of the machine. One bellow goes from the dispenser box, to the tub. This is where the water goes into the tub, to fill. The other bellow, is attached to the top of the tub, to vent. These both have or are suppose to have mushroom valves in them. If they do not, you're machine will leak water out the back of the vent.
Mar 28, 2010 | LG WM2233H Front Load Stacked Washer /...
Flooding during spin cycle w/ water level @ lrg.
I don't know what kind of machine you have, but we had the same problem just 2 days ago. Ours is an LG front loader. It turned out the problem was a bad bellows. You can get the bellows from the Repair Clinic (www.Repairclinic.com). I called them, and they were extremely helpful. The part was $14, and we were able to lay our washer on its side, access the bellows from underneath and replace the part. The bellows is a rubber hose-like connector. I read somewhere that hot water will cause holes in the bellows over time. This completely fixed our water leak. But I purchased 2 of these parts so that I have one for when it happens the next time. Good luck!
Feb 25, 2010 | Washing Machines
Leaking water
If your LG washer is a front loading machine, the bellow or gasket may need to be replaced. this is a common problem with front loaders as the bellow can be pierced by anything that may be in or even on your clothes. I would visually inspect every inch of the front bellow to see if there is a TEAR or PIN HOLE. this can be hard to detect sometimes but can save you alot of grief. hope this helps
Thanks
Oct 11, 2009 | LG Washing Machines
Maytag gas dryer
Two highest probabilities are that the belt is worn and slipping on the motor pully or that the motor is drawing too high of amps, working too hard, wore out. Also if there is excessive lint in the internal air chamber this can also be a problem. To reduce the suction draft of your blower remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not runnig straight through then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. This wont really fix the main condition, but it will not hurt. Remember this tip on future driers and you will make the dryer blower motor last much longer and it will lower your energy consumption.
Jan 27, 2009 | Maytag PYE2300AY Electric Dryer
LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
  1. draining the water.
  2. laying the washer on it's back.
  3. removing the hose clamp on the rubber bellows that connects the drum to the condensing unit (right hand side of machine).
  4. digging the lint wads out with your fingers and a small screwdriver.
Happy drying!
Jan 15, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WM1814CW - Water/soap Leaking Under Washing Machine onto Floor
Here is the answer !!! My LG front loader has leaked once a year for the past 4 years. The rubber bellows (a part underneath the washer) cracks and causes the leak. DO NOT LET THEM TELL YOU THAT YOU ARE USING TOO MUCH DETERGENT ... THAT JUST AN EXCUSE !!! The part costs around $12. Here's the link ...
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx?R=1514&searchText=LG%20Washer
Feb 10, 2008 | LG WM1814CW Front Load Washer
Dryers Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
