Question about Breadman TR2200C Ultimate Bread Maker
Excessive wear between paddle and panshaft?
I have a TR2200 that has received a lot of use for a number of years. I recently notice that the paddle seemed to be a bit wobbly when mounted on the pan shaft. It looked like there was a lot of wear. The paddle being aluminum, I assumed the wear would be mostly on the paddle, so I ordered a replacement. The new paddle is not as loose fitting as the old, but is certainly not snug. I had never noticed this before. QUESTION: Should the paddle fit snugly on the shaft? That's how I think I remember it. Might the shaft itself be worn? Need I replace the pan assembly? Thanks for your help!
John
  • Anonymous Jan 25, 2009
    I have the same problem. Can't seem to find the pan, plenty of sources for the paddle.
  • Anonymous Mar 07, 2009
    same problem on a brand new 2200C Ultimate (not so "utlimate"machine,,,paddle falls off in kneading cycle...called the service number in the manual...they wanted to sell me another pan with a "tight fitting" paddle...after a discussion they are sending a replacement...so there are replacements at a cost.
You can drill and tap the paddle, where it faces the flat on the shaft, and install a small setscrew. Something like a 10-32. Make sure you use a nylok screw or use a thread locking compound (available @ auto parts stores) to prevent the screw from working loose and getting into your bread! Just tighten the screw enough for a snug fit so that it can be removed for cleaning.
Posted on Feb 14, 2009
One paddle on my machine does not turn when under pressure
Take the bottom panel off to see if a belt is broken or slipped out of position.
Jan 22, 2015 | Kitchen Appliances - Others
It is not mixing all the way. Nothing is jammed. 3 loaves now have not come out, because clearly it hasn't been mixed thoroughly, like it used to. No burning motor smell.
Hi and welcome to FixYa, I an Kelly.
This can be caused by a few things.
1. Check the bread kneading paddle(s). Make sure that it fits properly and is not slipping on the drive shaft. Also look for cracks in the paddle blade hub.
2. Check the bread pan coupler and drive pan bearings (link is a picture reference only of a USED part. http://cgi.ebay.com/Breadman-bread-machine-TR2200-Parts-Coupler-/200535459633?pt=Small_Kitchen_Appliances_US&hash=item2eb0d84731 (klunking sound usually noted if this part has failed)
3. Inside the bottom of the unit check the belt tensioner. (Picture reference only!)
http://cgi.ebay.com/Breadman-bread-machine-TR2200-Part-Belt-Tensioner-/200535465293?pt=Small_Kitchen_Appliances_US&hash=item2eb0d85d4d
Usually if there is a belt or tensioner problem you will note a lot of rubber pieces in the bottom of the unit.
Thanks for choosing FixYa,
Kelly
Feb 06, 2011 | Breadman TR2200C Ultimate Bread Maker
I need a replacement bread pan and kneading paddle for a breadman Pro tr-777spr. Anyone out there know where I can get one?
My bread pan is not too bad, but my kneading paddle is rather beat up, so I kept searching online and finally found a site ABTECPARTS.com that had the kneading paddles so I ordered two. Hopefully that will take care of my problem. It helped that I found out accidentally that the same paddle (part # 20274) fits three other Breadman machines (TR2200, TR220-C, & TR2200--97) so I just kept searching and about 2 a.m. I found this site. I hope this will help others looking for paddles.
Jul 30, 2009 | Breadman Kitchen Appliances - Others
I am also in need of a pan for my breadman 2200C.
If I cant get my breadman ultimate tr2200 fixed, I can ship you my breadpan. I guess that would be better than throwing it out. It is like new.
Jul 20, 2009 | Breadman TR2200C Ultimate Bread Maker
Excessive tire wear on front right wheel only
re alignment point to toe in-out
Mar 29, 2009 | 2002 Volvo S60
Need replacement pan for Breadman 2200
Hi
You need to go here for spares
https://secure.prodregister.com/prodprotect/applica/bm.shtml
Feb 02, 2009 | Breadman TR2200C Ultimate Bread Maker
Paddle fan shakes at high speed. How do i balance?
Generally speaking, all paddle fans shake to some extent but if yours seems excessive, you mave have a bent paddle bracket. Try unbolting ( usually 3 screws per paddle) the blade from the bracket while leaving the bracket attached to the motor.. Then run it up at high speed... If it still rattles a lot, you've got an out of tolerance bracket, if it runs pretty smooth, you can put the paddles back on and try it again. ( sometimes reseating the paddles and making sure the hardware is secure will solve your problem) If it turns out that your paddles are the cause of the problem, you can purchase replacement paddles from Home Depot or other home improvement stores.. Hope that helps...
Aug 14, 2008 | Heating & Cooling
B&D Bread maker all in one
I think the problem is that the bushing - the tubing that the paddle passes through - wears down (corrosion) and jams after a few years. I took mine apart and found that was the case. So a new pan has to be ordered. I'm trying that out now via the B&D 1-800 number.
Jun 12, 2008 | Black & Decker B1561 Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
362 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
