Question about Jeep 2002 Liberty SPORT
My 2002 jeep liberty sport makes a grinding sound everytime I engage the 4wd parttime and fulltime
Every time I try to engage my 4wd into part time or fulltime I pull the lever back into the appropriate position, and after 1 to 2 mins it starts making a loud grinding noise, so I immediately disengage it....please help? Also every time I fill it with gas, no matter whether it is empty or half full, it stalls multiple times before it will finally turn over, and then runs badly until I shut it off and restart it, then it runs fine?
davespcr
  • 115 Answers
SOURCE: when in 4wd it makes a noise
Is the noise in the front or middle? If it's in the front, it is most probably a wheel hub or differential case bearing. First I would check (or replace) all the gear lube in the transfer case and both differentials.
If the sound is under the middle of the jeep, it's probably a front output bearing in the transfer case.
Posted on Jan 16, 2009
  • 21 Answers
SOURCE: 2005 Jeep Liberty stuck in Part Time 4wd
I questioned the dealer about my 2005 because mine was disengaging what I thought to be rough compared to what I was used to. They told me that I should shift the vehicle into Neutral before shifting the selector. I have also found that shifting between Reverse and Drive a couple of times while stopped has helped as well. By doing these couple of things, I have had no trouble since. I hope this helps as it might at least be something to try.
Posted on Jun 25, 2009
  • 105 Answers
SOURCE: I just replaced my battery in my 05 jeeo liberty
just remove front pannel of radio which is removebly. there is a reset switch hidden find it and press it for 5 seconds.
Posted on Jul 11, 2009
  • 6982 Answers
SOURCE: 2002 jeep liberty Turn key switch makes loud
See that? Every once in a while I'm right!!! Reason is that the starter draws far more than anything else in the car. Lights and radio can easily be run by an otherwise ineffective battery, but when loaded (starter draws a bit less than 200amps), the battery will fall flat on its' face! When you jump it, the car is running off the alternator and seems to be OK, till you turn it off again.
Posted on Aug 27, 2009
Testimonial: "AWESOME, RIGHT IN THE MONE. SAVE ME $260.00 and a lot of headaches."
RadioMedics
  • 10 Answers
SOURCE: Jammed CD
Hello, I see your post is a few months old. If you still need help or a solution for this problem please feel free to contact me at rcruz@radiomedics.com
The loss of power to the unit should not have affected the CD player. It will re-sync upon powering back on but that is normal.
Regards,
Robert Cruz
1-877-4-RADIO-MD
Posted on Sep 09, 2009
Squealing noise when auto locks engage
scan it, yet, that is first (after checking fuses)
scan it see whats up. and for sure 2007+ jeeps. big time.
the check engine light is on (oBD2 check light?)
we cant do noise here.
deaf
but you can find the location, nothing else matters, the spot that makes noise.
what did you do, did you select 4wd or what?
The Liberty is available with either a part-time Command-Trac or full-time Selec-Trac transfer case.
if yes, which system do you have, we cant guess any of this.
Feb 16, 2015 | 2007 Jeep Liberty Sport
When I take my liberty out of 4 wheel drive, every once in a while I get a clunking noise in the rear end area
is this Parttime 4wd or Awd OR USING LOW RANGE OR LOCK.
we cant guess this.
parttime is not for dry roads, only ice or dirt.
so if using PT or lock, it will complain, and causes,damage.
read the operators guide yet?
these cars come with various, drive line options
state yours. for good answers.
Jan 18, 2015 | Jeep Liberty Cars & Trucks
Intermittent starting
Yes. When was the last time you had the starter changed? Has anyone crawled under the vehicle to check for a loose starter? If the starter does not engage it may be the starter solenoid ( the thing that drives the gears into contact before the starter actually turns ). This might not be ramming the gears together properly and that will cause the grinding noise, as well as an intermittent start.
Nov 07, 2013 | 2002 Jeep Liberty
I have a 1999 dodge sport 1500 4x4 and it makes a clunking sound like it is skipping gears when I engage it in four wheel drive at times. I checked all fluids and changed them and checked u-joints and all...
4X4
On these issue, there are few solved help links for troubleshooting the issue easily.-------
Click the link below: ---
No 4x4 light on dash?
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Car will not go into 4WD high or 4WD low?
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
4 wheel drive system will not disengage?
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
4WD light is flashing and beeping? NO 4WD high?
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
2002 Jeep Wrangler: 4WD Idiot Light is ON?
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
4x4 front differential will not engage the axle on ford?
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
4x4 will not engage on Ford F150?
http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4 light keeps flashing
4X4 LOW LIGHT IS FLASHING ON DASH
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
Ford 4x4 front wheels will not engage?
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These details will help.
Thanks.
Dec 12, 2012 | Cars & Trucks
Wont turn over makes a click sound
The click sound is the starter relay closing. The pinion gear of the new starter may be jammed; otherwise the starter would spin but not turn the engine over
Sep 15, 2012 | Jeep 2002 Liberty SPORT
1994 grand cherekee limited fulltime 4wd want to change to select a shift transfer case from1994 cherekee sport
You are wanting to build a "franken-jeep" and you are wanting somebody to tell you how to do it? I have 2 words for you... GOOD LUCK! You should probably try a Jeep forum someplace where they talk about doing stuff like that all the time.
Jun 18, 2012 | 1994 Jeep Grand Cherokee
On my 2002 Jeep Wrangler Sahara M/T My
Try taking the gauge cluster out and cleaning the connectors then apply some dielectric grease. this may help with the speedometer. to remove the gauge cluster, pop off the top vent cover (3 clips), then remove the knee guard under the steering wheel. After that you will see two screws holding down the bottom part of the gauge cluster and 2 more on the top. Hopes this helps!
Feb 26, 2010 | 2002 Jeep Wrangler
2000 Jeep Cherokee Gear Grinding & 4WD Whine sound
Give a try by change your transmission/filters and Transfer case oil.
Oct 27, 2009 | 2000 Jeep Cherokee
Jeep 2002 Liberty SPORT Logo
29 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
