Question about Mitsubishi WS-65807 65" Rear Projection Television
About 10-20 minutes after I turn it on the screen breaks up into little colored lines, the image loses focus for a few seconds then it clears up, it does this 2 or 3 times in the next 5 minutes then the picture is fine until I turn I turn it off again
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
When it does this go with the Mitsubishi remote to the menu--look for convergence-then advanced= you should get a grid of yellow lines and if see red ones not lined up the set uses one or two convergence chips ( I can look for you).
It is very common for the chip/s to act up when cold or after warmup--convergence will seem to jump in and out when that happens---in 100% of the cases I have seen (about 500) replacing the chip/s cures this and for most models I have the instructions for this repair of my own from having repaired hundreds of these sets.
Posted on Dec 10, 2012
5 Suggested Answers
  • 185 Answers
SOURCE: When I first turn on the TV everything is clear
convergence section starting to break down will need attention
Posted on Jun 22, 2010
techman
  • 3130 Answers
SOURCE: problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Posted on Jun 05, 2007
maatmartin7
  • 1216 Answers
SOURCE: Mitsubishi VS-4552A
I have to agree with Techman. Very good solution and advice.
Posted on Jul 15, 2009
taran_2005
  • 10515 Answers
SOURCE: my mitsu WS55819 looks fine
Hello, friend you have a convergence issue, first see if they will move manually in your menu, they should be able to move up down left and right, and if not this is when two chips labeled STK392-xxx Failed. They can be located by finding the largest heat sinks in the unit.
Along with the possibility being an open resistor and or open fuse in the convergence circuit. All of the resistors around these chips should be checked pay attention to the ones that are standing up and they all should read low ohms, If they are in the k ohms they are probably open which is bad ,This is a tricky repair, if you have Never done this repair I don't suggest it friend.
But if you are willing to tackle this problem the only step by step procedure I found for you would be to watch someone do the repair, and this I found on the internet in the convergence problem screen. This will give you an idea of the work involved and also what the parts look like.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 29, 2010
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Image out of focus after it warms up
unfortunately this suggest that either, one of the capacitors is leaking or resistor on the bulb supply... or bulb itself, in all cases will cost money to repair...
Jan 09, 2015 | Optoma HD20 High Definition 1080p DLP Home...
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
I have a Sony KDFE50A10 50 inch HDTV When I turn it on for it has the lines verticle on it it takes a few minutes and then clears...tv or cable?
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or vertical lines.You will need to replace the light engine.God bless you!
Oct 20, 2009 | Sony KDFE50A10 50" HDTV
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Color problem after warm up.
The probelm is caused by either a bad color wheel sensor, color wheel or formatter board. I have the new redesigned sensor assembly and color wheels that I can sell. It is best if you send me the projector for proper diagnosis.
Apr 30, 2008 | HP vp6320 Multimedia Projector
Problem with color
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
