Question about Canon CR-180
How do I replace the the rollers (feed rollers and seperation rollers) on a Canon CR-180 or 180II scanner?
Any documentation would be helpful!
  • Sheri Zeiders Dec 12, 2012
    I need to replace the feed rollers on a Canon CR-180 scanner. How do I take teh machine apart to replace these rollers?
3 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: Canon DR-5010c feed roller does not stop running after documents
Please blow air and clean the sensors. There could be a small piece if paper causing this. The scanner must be assuming that there is paper.
S. Mohan
Posted on Jun 12, 2009
mohanchennai
  • 490 Answers
SOURCE: I have a Canon Scanner DR7580 and the wheels are
The rollers slip if a) the document is slippery or dirty, b) if they are unclean after usage or c) if there is hardware problem.
Try scanning a set of clean sheets, clean the rollers with a damp cloth thoroughly (no solvents pls). Get QUMA tool and check if the rollers are working independently.
S. Mohan
Posted on Mar 18, 2010
Fujitsu fi-5650C Error U1
Hello Ismail,
Error U1 referes to Frequent paper jam in Fujitsu fi-5650c scanner. In order to troubleshoot your scanner issue, you are advised to follow the steps provided below:
1. Do the documents satisfy the paper specification?
2. Have the documents been prepared properly?
- Align the edge of documents for stable paper feeding.
- Remove documents with creases or dog-ear corners.
- Scanning different widths documents may cause skew and result in paper jam.
3. Is the imprinter EXT cable connected to the scanner properly? (only when the imprinter is installed)
4. Clean the Pick roller, the Separation roller, the Brake roller and the Chute roller and see if the error is resolved.
5. Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
6. Replace the Pick roller, the Brake roller and the Chute roller, and see if the error is resolved.
- Check the consumable counter in the software operation panel. When the counter exceeds the values, replace the Pick roller or the Brake roller.
If the above steps do not help, then yuo are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Dec 16, 2013 | Fujitsu fi-5750C Flatbed Scanner
Scan multiple pages
Hello Chris,
Please check the followings:
1. Are the multi-feed conditions and paper quality requirements satisfied? - Please confirm whether the documents satisfy the conditions described in "Multi-feed detection condition" and "Document quality" of Error Recovery Guide.
2. Did you fan the document before setting? Has the document just been printed with copier or laser printer? - Please reduce sheets of the document or fan the document 3 to 4 times to remove static electricity.
3. Is the thickness of the bundle of documents less than 5 mm?-Please reduce the number of sheets of the document to satisfy the condition.
4. Is the Brake Roller dirty? - Clean the same
5. Is the Brake Roller set properly? - Please install the Brake Roller correctly.
6. Is the Brake Roller worn out? - Please check Brake Roller and Pick Roller counters, if the recommended cycle has exceeded or if the Brake roller is worn off, then please replace the Brake Roller.
If the above information doesn't help, please contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Aug 21, 2013 | Fujitsu fi-6130 duplex scanner
Scanner has been used for a few years, and is frequently pulling multiple items through at the same time. We have cleaned the rollers with alcohol wipes, and fed the waffle papers through to clean.
If this is a Canon CR-180 or 180II machine then the feed tires need to be replaced. Often if you are using the grey feed tires, the middle one will come loose from the platic hub and cause this problem no matter how much you tighten the tension wheel. The part numbers of the seperatrion roller assembly and the feed tire assembly are as follows.
MG1-3530-000 Seperation roller (has 3 tires)
MF1-4210-000 Feed roller (has 2 tires)
You can also replace the two in the hopper area, they are:
MF1-4352-000
MF1-4353-000
That is a common problem on older machines; hopefully that helps
Feb 24, 2011 | Canon CR-180
Canon Imagerunner 220- Autofeeder not working
there is the possiblity that the document feed rollers and seperation pads are dirty and need cleaning and or replaced. and or the clutch that turns the rollers is slipping or burned out.
i would start with the rollers and pad they are least expensive and easiest to replace.
May 28, 2010 | Canon imageRUNNER 2200
I have a Canon Scanner DR7580 and the wheels are hesitating upon feeding of the document.
S. Mohan
Mar 15, 2010 | Canon DR-7580
Multi feeder not working
Is the document tray raising? If that is okay, then clean the rubber rollers with a damp cloth. If worn out replace.
S. Mohan
Aug 04, 2009 | Canon DR 3080C Path-Through Scanner
S. Mohan
Jun 11, 2009 | Canon DR-5010C Scanner
Canon PC 1080 F ADF Problem
call canon for instructions on how to clean feed roller and ADF path; otherwise probably need new seperator pad and possibly paper feed roller
Aug 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon CR-180 Logo
77 people viewed this question
old marine
old marine
