Intermittent no spin
Machine goes through all cycles except intermittent no spin. Balance load feature tries six or seven times but then quits. Load is not out of balance and by starting cycle over or unplugging machine "Sometimes" will spin. No change in load, balanced load, but the machine senses that it is out of balance. Door switch was changed but that did nothing to fix problem. During fault code test there is no faults listed.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 10, 2012
  • 6 more comments
  • Steve Battaglia Dec 10, 2012
    WFC7500VW 1
    The thing is still under warranty but the Tech's keep looking for an error code that does not come up so they say No Fault. The machine performed perfectly for the first 8 months of its life, now this is becoming about a twice in every 5 loads and I am getting unhappy with the No Fault found excuse.
  • Richard Roth
    Richard Roth Dec 10, 2012
    I am leaning toward the door lock. Check to be sure that all the screws are tight and when the door is closed and it won't spin, instead of opening it, push in on the door to see if it will start. Keep me posted.
    Have pushed on the old door lock and the new with absolutely NO EFFECT. Was told to secure the door by pushing on it and have done that as well. No effect and no change with the old or new switch. Since it is intermittent it would seem pushing on the door switch would help, it doesn't. I am not sure what a Motor Control effect would be and I am wondering what the fault code if any for a motor control that has an issue. Also no door lock fault code since changing the switch but no change either.
  • Richard Roth
    OK, if it is under warranty I would call Whirlpool and raise 9 kinds of hell. They will get it straight for you. Anything you might try will void the warranty.
    Hope I was clear that the Door Lock Switch was changed by the Tech as the code for it was displayed. There is a smaller push button switch above it and I am not sure what it is for but that was not changed. It is a small, 3/16" round button which is depressed by the door when it is closed. The one they changed is the door lock switch which is below it with the rectangular hole where the lock tang on the door fits in.
    I am planning on going after Whirlpool with my issue since it remains under warranty but because I seem to be getting a lot of deer in the headlight looks from the Techs I want to be at least armed with some information other than the No Fault Codes Shown. My frustration is that it takes a week to get a Tech out here to tell me the same things I already know. I absolutely will not touch the thing since it is a warranty issue and of course each time a tech shows up I am sure the clock is running. It takes about one day for the No Spin to start up again, about 2 of every five loads after that and it appears to be on the increase.
  • Richard Roth
    It sounds like a wiring issue then. Well, keep me posted!
SOURCE: off balance during spin cycle
I have a Performa Model PAV3200AWW that would go unbalanced every time it would go into a spin cycle. I found the problem to be a worn out snubber. This is a plastic ring that is at the pivot point for the whole tub. It separates the metal to metal contact at the bottom of the washer pivot point. The part is less than ten dollars, but it is a quit a job to replace. I had to remove the whole tub to replace mine, but it did solve the problem. If you see a lot of plastic shavings around the pivot point, then this could be your problem.
Posted on Dec 15, 2007
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
BIKER T
  • 909 Answers
SOURCE: spin cycle is off balance washing machine is
i dont believe it is the agitator per say. Assuming this problem has just started and doesnt have transportation bolts still attatched. Two conditions cause the imballance. 1)(if unit is a top loader) Check if all 4 shock absorber springs are well lubricated and not sticking. 2)A more involved problem which often happens, Underneath the washer, is the drive motor. on the motor, is a round pulley. this pulley needs to come off and strip further until you see a long spring. If it is not broken, clean it up using a solvent and a rag. reassemble and test. (if spring is defective, it will slip instead of grip on a spin cycle.
Posted on Sep 17, 2009
  • 3 Answers
SOURCE: maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Posted on Jan 08, 2011
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
The beep that signals load is done sounds prematurely for about a minute ,the dryer continues until load is dry then shuts off
On this dryer each of the seven automatic cycles listed on your machine perform different functions based on fabrics, load size or variables. In essence the first four settings (Heavy Duty to Delicate) relate to your desired drying temperatures of high, medium, low or extra-low respectively. The moisture level of the load is determined by the dryer's sensor system and the machine will set the drying time to an optimal level.
Whirlpool added a WRINKLE FREE feature or what one might describe as an extended intermittent tumbling time. This added cycle helps reduce wrinkling when you may not be able to unload the dryer immediately after the end of the cycle when the buzzer goes off. Starting this setting is a simple one button operation at the control panel. TheWrinkle Shield™ Plus Feature is preset to on during the permanent press cycle.
Jan 30, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Anytime this machine goes into a spin cycle it is grossly out of balance. we have tried adjusting the load; reducing the size of the load; we have gone to just one towel in the washer and still out of...
Are the locking nuts tight on all 4 legs? If not, tighten all locking nuts after leveling machine. Also, place a glass of water about 18" in front of machine while spinning and see if water moves. If it does, you may have flooring issues.
Sep 11, 2010 | GE Energy Star WCVH6260F Front Load Washer
Very noisy on spin cycle, not out of balance
Hi, check leveling of machine, machine should be proper leveled on all side, use spirit level to adjust legs, there should be no rocking motion, in any direction after leveling, put hands on top of machine and try to rock it sids to side, there should be no movements, also check for overloading, be careful when washing things like bath towels, etc, they absorb lots of water, eg. one regular bath towel are equivalent, to six pants, six tops. or possible springs or bushings broken, you need open machine and check.
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine drum makes loud noice in the spin cycle. Makes the same sound that a top-loading machine makes when it goes out of balance. Help.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 20, 2009 | Kenmore Washing Machines
Bosch Nexxt 700 spin problems
yes it could be normal if the balance control senses that the load is uneven however the same problem could be caused by a blocked filter or blocked sump hose.
Dec 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
My PAVT920AWW won't spin hard enough to get all the water out
I have had teh same problem. I calledin the Maytag service and they did replace something out of goodwill but the technician told me that the load balance sensor is sensitive. If your load is unbalanced then the machine will spin slowly so it does not walk across the floor. With larger loads the wieght will make the machine bang against the sides and walk.
The solution is quite simple. Make sure the load is balanced. The agitator has a way of unbalancing a load from time to time so you need to do this manually. It is a very rare occurance and it is best to make sure your load goes into the machine balanced first.
Dec 19, 2007 | Maytag Performa PAV2200
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Clothes too wet
Watch the washing machine go through its complete spin cycle.(It could have a filter in the pump,check for water flow coming out of the drain. Make sure the washing machine is fully leveled with a square. make sure you put fairly big loads to keep it balanced. If the washing comes out wet on the final spin ,add some more garments and then put it on spin again as the w/m might be going out of balance. Under the work bench on top some times there is a spring to adjust the tension. about every five or six years the motor brushes need changing.
Jan 04, 2007 | Bosch WFL 2463 Front Load Washer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
