Question about GE GSL25JFPBS Side by Side Refrigerator
GE Profile Refrigerator, water used to come out cold, however now is coming out hot
Water used to come out cold from the dispenser, however now is coming out hot
  • Ronn Dec 12, 2012
    My GE Profile refrigerator is a over and under, freezer on top, refrigerator section bottom. Ice maker works fine, however water comes out of the dispenser hot. Water came out cold just a week ago.
    Top Expert:
  • GE Master
  • 9,472 Answers
Is the refrigerator section cooling? The water is chilled by the "looped hose" that is on the bottom rear of the refrigerator section.
Posted on Dec 10, 2012
  • Ronn Dec 10, 2012
    Yes, the refrigerator is cold and the freezer is working good.
  • 10865 Answers
SOURCE: water does not fill ice tray GE refridgerator
Hi Alice. If I was nearby I would stop by and take a look for you but since we are cyber only I will assist you and yes, you can fix this yourself!
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on Aug 15, 2009
SolutionGuy
  • 331 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Posted on Apr 01, 2009
  • 29 Answers
SOURCE: I have ge profile refrigerator tfx25pr with
THIS MODEL DOESN'T HAVE A FILTER
Posted on Nov 19, 2009
SOURCE: GE refrigerator freezer water dispenser failure GSH25JFTA
Some have said that if you are fridge is still making ice, then your water line may be frozen. So you need to let it thaw out by leaving the freezer door open. Figure out somewhat to try and keep the cold air in by using plastic sheeting or something, until the line thaws. You can't dispense water with the door open, so reach up press the button that makes it think its closed and try to dispense the water..or just shut the door to test it out. I am going to try this when I get home today, because I am having the same problem on my GE model# GSH25JFTA BB.
Posted on Mar 29, 2010
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
No water coming out of hot side of dispenser, only cold
Like most coolers that have "hot" works of a "preheat" if you are not pumping out anything there is an obstruction that needs to be cleared.
Oct 23, 2013 | Sunbeam Hot Shot Hot Water Dispenser...
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
Hot water coming out of refrigerator water dispenser
The only way hot water will come out of the dispenser is if the main house supplying the unit is tapped into the hot water line instead of the cold.
Jul 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Pelonis Hot & Cold Water Dispenser, water not cold
I too am having just room tempature water coming out of the cold
dispenser and I have had mine for 1 month.........
Nov 03, 2009 | Kitchen Appliances - Others
I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Jan 21, 2009 | PUR Air Purifiers
Warm water out of water dispenser
If this is a new hook-up please be sure that your water line is connected to the cold plumbing on the house and not the hot.
IF it is on the hot the fridge is cooling it down to warm.
Please let me know if this helps you.
Jan 06, 2009 | Whirlpool Refrigerators
Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Oct 05, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
GE GSL25JFPBS Side by Side Refrigerator Logo
198 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
