Question about Chi Mei Corporation CMV-946D/A Monitor
I have LCD monitor Chimei model CMV 946A,19" and I like to open it and change the fuse,how I open the back panel?
Need to check the main Lamp,how do I do it??
Can I purchase a replacement stand for my chimei 222H monitor? If so where?
I have broken the mounting arm of my Chimei CMV 222H ...
www.fixya.com/.../t14977283-broken_mounting_arm_chimei_cmv_222...
Nov 12, 2012 - ... the mounting arm of my Chimei CMV 222H monitor, can you getreplacement arms? The locking mechanism - Chi Mei Corporation CMV-222H 22 inch LCD Monitor question. ... Video; Photos; Link; Replacement Parts. Add.
Repair Kit, Chimei CMV 221D, LCD Monitor, Capacitors ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Dec 15, 2015 | Computers & Internet
My monitor Chimei CMV 946A gets 2 sec. picture but then went black. power still on
Excuse me but your descripton is not clear enough. Do you get ALWAYS 2 seconds of picture and then your monitor goes black or it went black after 2 seconds and you never more got a screen
In any case, ask help from a friend, letting you to connect your monitor to another computer. Would pinpoint problem and discard eventual video card issue.
Aug 22, 2015 | Computers & Internet
I have a 19" cmv
How old is it? If it still under warranty get it repaired, it sounds like the switch is gone or the energy saving s/w inside is bad and is not detecting when/when not to turn the display on/off.
May 22, 2011 | Microsoft ChiMei CMV938D 19" Widescreen...
Where can I download an English manual for a CHIMEI - CMV633A monitor. The ones on their site are only in Chinese. Thank You
try www.chimei.com.tw then you click on the English. it will give you the English version.hope this helps.or try www.scribd.com or www.w9drugs.org
May 07, 2011 | Chi Mei Corporation CMV-633A LCD Monitor
I have exactly same problem
Sound like your display is having issues with the inverter board. When the power supply detects a short circuit, it turn off by itself. When you try several times, you may be able to "bypass" the circuit protection but the damaged parts still having problems. This issue may be related with the DELL display issues.
The display needs to be fixed by someone with experience in electronics repair.
Sep 29, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
19"chimei Lcd. Screen stays black.
probably power supply, dac-19m015, 2200uf bad capacitor.
Apr 26, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
Chimei CMV 938D 'Out of range' error message only when using DVI Connector on specific resolution and color depth
I know this sounds obvious but- I had the same problem, and turns out the cord want plugged in quite properly at the back of the monitor. This may not fix every problem, but, I suggest you check the cord pligged in at the back of the monitor is firmly in there and restart, then if you still get the problem, contact the company.
Jul 21, 2008 | Envision EN-7100e 17" Flat Panel LCD...
CHIMEI CMV T39D
Sorry to hear that you are having problems with your monitor. While the monitor is turned on and plugged up to your computer system, try looking very closely at sharp angles from above, if you can barely see your desktop the problem is the back lamp inside your monitor. Make sure the settings are not in sleep or standby mode first. If it is your back lamp you can check the following websites for information on how to fix them: The first one is here
The second site requires free registration and you will find the information you need in the members section, the main page is here. Since your monitor is less than a year old, you might want to consider sending it back to the manufacturer since they usually give you a 1-3 year warranty on the products. The only thing you should have to pay is shipping and handling. You stated that you changed the cables and tried hooking up the monitor to a known good system and that still did not help the problem, so I believe the problem may be the back lamp. I hope this helps fix your problem and if you need further assistance please let me know. I wish you the best of luck.
If you would not mind rating my help, I would really appreciate it. Thanks
Jul 07, 2008 | Chi Mei Corporation CMV-T39D Monitor
Elongated desktop and software screen images
Many graphic cards enable you to rotate the screen up to 360 degrees. You could try to post this question again under you graphic card model instead of computer screen model as it is your graphic card that is certainly the problem.
Jul 25, 2006 | Microsoft ChiMei CMV938D 19" Widescreen...
Chi Mei Corporation CMV-946D/A  Monitor Logo
89 people viewed this question
Top Chi Mei Corporation Computers & Internet Experts
Jax Planet
Jax Planet
richie46
ray gallant
Are you a Chi Mei Corporation Computer and Internet Expert? Answer questions, earn points and help others
