Question about Microwave Ovens
I have a Goldstar mv1610ww that is currently set up for external/ducted venting. How do I switch it to ductless/recirculated venting? What additional parts do I need? It currently has the perforated v
I understand this over-the-range microwave can be vented either ducted or ductless. I want to switch it to ductless.
  • Microwave Ovens Master
  • 9,047 Answers
That information is in your installation manual that came with the oven.
If for some reason you don't still have that, then you can order it or see a video at LG's site.
The LG product support page for your model is here.
If you'll scroll down to the middle video, they show you how to install it.
That will help you when you uninstall the oven so you can swap the vent fan assembly around.
I would bet you'd also need to order a charcoal filter.
The service manuals is here, but it does not contain part numbers.
You can get LG part numbers and order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Dec 12, 2012
Testimonial: "Thank you so much. You are correct in that I don't have the manual that came with the oven as I am not the original owner. What you have said here sounds exactly right based on my (albeit limited) research; I think you're right that I have to get a charcoal filter. And a smooth-face vent plate as well. Thank you, I really appreciate your help! "
MicrowaveSvc
  • 9047 Answers
SOURCE: internal venting of KitchenAid Microwave oven hood combination
That info is in your installation instructions, which can be found here.
Posted on Jan 03, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Front vent on JMV8208A Jenn-Air Over-the-range microwave hood keeps opening
There may be an option to turn that off with the keypad, but your best bet would be to contact Jenn-Air.
The manual will have their contact info or you can see: http://www.jennair.com/content.jsp?name=contact_us
You can download the owner's manual and installation manual here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMV8208A&siteCd=JA_EN_US
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
scottowa
  • 87 Answers
SOURCE: Installing a Whirlpool over the range microwave
I would say that you do not have to vent it outside. One of the most common complaints I get is that the microwave is not sucking up a lot of air. I have called Whirlpool and they have said that most of these newer microwaves don't really have a lot of air movement in them and they have smaller blower motors. Some of this was due to the fact that people didn't like the noise of a big fan that was necessary fo move air. I have noticed this on my own also. When boiling sweetcorn this summer, it would barely **** up the steam whether it was recirc or to the outside, I usually test them by putting a cleenex under the vent abd see if it holds it there. Bottom line is they really don't move a lot of air and it's not worth the cost and time of venting it out. Hope that helps
Posted on Mar 08, 2009
  • 574 Answers
SOURCE: Need vent grille for Whirlpool MH2175XS
Go to www.partselect.com and type in the model # you will find it there.
Posted on Mar 10, 2010
SOURCE: I have a GE Spacemaker Microwave DE68-40861A that
take microwave down. There is 1 screw on the back that hold fan in. Pull screw out and the fan will lift out. Roll fan so that opening of fins faces to the front. set it back in put screw back in and remount microwave.
Posted on Nov 04, 2011
I have a GE Spacemaker Microwave DE68-40861A that has a built in range vent. The fan motor blows just fine, but there is no airflow. Apparently this was installed improperly. What would be blocking the...
Nov 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My Gold Star Microwave Oven MV1610WW Stopped Heating. It turns on but does not cook.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[p]]][p
May 31, 2010 | Goldstar MV-1526 Microwave Oven
Can i vent my jvm-1440 microwave/fan ?
yes, you can recirculate it out the front which i suppose u do currrently... you may also vent it out the top, or the rear. to do this u must drop the unit down,and rotate the fan motor to point the appropriate direction, and also install or have a exterior venting piping existing currently..
Apr 16, 2010 | GE JVM1440 Microwave Oven
Still operable
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Jul 30, 2009 | Goldstar MA-1011 Microwave Oven
Change the venting from internal to external?
Hello staufferbi,
It is possible to redirect the vent to the outsied but it is not a simple task. First off, you will need to remove the micro from the wall cavity and reposition the blower so that it vents out the top and not the front, then cut a hole in the cabinet above the micro ( lined up to accept the rectangular duct ) These tasks require fairly good carpenmtry skills and may not be suitable for the novice.. In any event, if you do attempt this.. then once you have the duct vented through the cabinet from the top of the microm you will need to attach that to wall vent feedthru. This normally means converting the rectangular duct to 4inch round and using an elbow. Needless to say, it can be done but is fairly involved. I did not mention anything about getting a 4 inch hole thru the outside wall and not thru a wall stud.,. Outside walls are typically bearing walls and although your roof won't cave in if you cut a hole thru a stud, it isn't advisable. Then you have to make sure it is sealed thru the wall cavity and properly cut into your siding. As I said before..it can be done but don't think it is a little job..
Good luck
Rick
Jan 09, 2009 | Microwave Ovens
Internal venting of KitchenAid Microwave oven hood combination
Jan 03, 2009 | KitchenAid KHMS105E Microwave Oven
Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Sep 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a over the range microwave and I need the support bracket the holds the unit up. where can I get one. model number is goldstar MV161OWW is there anywhere where i can order? and it there a...
That model should be MV1610WW.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Goldstar owner's manuals can be downloaded here.
Sep 25, 2008 | Goldstar Microwave Ovens
Mvh1615
It doesnt matter how old a system was. components can be failed at any point in time. unplug the unit. carefully disassembly and visually check the diode near magnetron and capacitor, it might be broken.If seems good, check the thermostat continuity,if beeping. changage your magnetron. be careful capacitor store charges that deadly. discharge the capacitor first.
when you change mag. change the diode too.
Jul 24, 2008 | Goldstar MV-1501 Microwave Oven
Dec 03, 2007 | Jenn-Air JMV8208A Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
