Question about Exercise & Fitness
Replacement seat rollers needed for rowing machine
I'm looking for a replacement seat roller. Single flanged, 33mm diameter, with a flange that measures 42mm dia., 3mm wide. The width of the wheel is 22mm, it takes a 22mm dia. bearing and the bore is 8mm dia. I'm just after the wheel, (made of polyurethane) but if you know of something that fits these dimensions and comes with bearings, then that could work. Thanks for your help.
I need a seat to a Carl Lewis Romf51 rowing machine
Fixya does not sell replacement seats.
Aug 29, 2016 | Exercise & Fitness
Is there one or two rear wheel bearings on 95 Toyota Ford runner 4wd
If the axle flange has a series of nuts around the perimeter then you will have 2 bearings (tapered roller) per side. IF you have a flat flange and no nuts then you have a single ball bearing or taper roller bearing per side. I suspect 2 bearings a side as they run the same axle housing as a hi-lux
Sep 08, 2013 | Cars & Trucks
Need to know how to set the pinion nut.
the purpose of the collapsible spacer is to get the correct pinion bearing pre load. First step is to know the required pinion preload setting for your diff. Assuming that you have the correct mesh for the gears then insert the pinion seal. Assemble the pinion flange and do up the nut while moving back and forth the pinion flange to allow the bearing rollers to seat properly. using a suitable torque measuring procedure adjust the pinion nut until that torque setting is reached. ( suitable is the correct tool or attach a round disc of known dia to the flange and by calculation of radius times force ---from say a spring balance with a string wrapped around the disc--) That is to say 12 lb pull on a 4" radius disc will ==48ft/lb torque. All diffs using a collapsible space are assembled typically..; My reference is ford
Apr 20, 2013 | Cars & Trucks
Hansgrohe 88509000 sink drain does not close completely, water slowly drains out
This could be caused by the installation. If the installer did not use plumber's putty between the the flange and basin it will not seal with the basin. Another possible cause is if the basin is not perfectly formed it will cause the flange to oval or not seat evenly. If this is the case it may leak between the flange and the basin or the stopper may not seat all the way down and it may leak between the stopper and flange.
Oct 16, 2012 | Hansgrohe 31060821 Metris S Single-Hole...
We have an MFC 7820N Printer that is printing a dark vertical line down the right side of the paper only when we fax or make copies through the top tray. Please help we have replaced drums, toner,...
usually this happens because of the toner. But since you replaced that try looking at the rollers below the toner. Take out the toner cartridge and look at the rollers. sometimes ink can try on them and cause a strip on the paper. Use some rubbing alcohol on a paper towel and clean them.
Also you can go into the printer settings and do a "clean paper path" this will require you to run a piece of paper the printer will print out to try and "self clean."
Here is a link to the Brother website for the Manuel.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc7820n_all&dlid=&flang=English&type2=-1
May 05, 2011 | Office Equipment & Supplies
Hello, People I have a Tunturi 202 rowing machine, and love-it. However, the little wheels under the seat have worn-through ... weep! Can anyone help me on locating replacement wheels for the...
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Mar 10, 2011 | Exercise & Fitness
How many thermoststs does the nissan nomad have
1 this being the specifications on it
Features & Benefits Quality Controlled Factory Calibration Assures Accuracy Of Opening & Closing, Regardless Of Pressure Changes. Positive Piston Heat Motor Provides Accurate Temperature Control. Sturdy Metal Construction Throughout. Attributes Depth from Flange : .82"
Design : Offset
Flange Diameter : 2.125"
Height from Flange : .91"
Jiggle Pin : Yes
Temperature Range : 195 Deg
Warranty Limited Lifetime-See Manufacturers Written Policy
Warranty PDF
Material Safety Data Sheet (MSDS) There is no MSDS for this item Application Information: 1990 Nissan Van Engines : 2.4 L 2389 CC L4 SOHC
Comments: 195 Degrees;Alternate Temperature
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Feb 27, 2011 | 1990 Nissan Minivan
I bought my son an old fashioned hot dog roller for Christmas. It worked great the first time and the second time he went to use it, the rollers wouldn't roll. I've read several reviews on this product...
The 5 rollers are operated by 9 small gears that a run by the center gear which is turned by the motor on your machine. The gears in between the rollers help drive the next roller as you move outward from the center. The gears are made of what looks like pot metal, (cheap junk). The teeth break on the gears easily and either stick or won't operate the next roller. You can take the unite apart using a thin screw driver an pry the 6 flange on the drive side and straigten the flange with needle nose plyers. It then prys apart. If any teeth are broken, you can only buy a whole new grill part from Nostalgia Electrics. Cost is 20.00. They won't just sell the junk gears
Jan 06, 2011 | Nostalgia Electrics Hot Dog Grill Roller...
Worn seat wheels on Tunturi 202 need replacing
Jul 01, 2009 | Tunturi Exercise & Fitness
R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Mar 31, 2009 | Exercise & Fitness
Exercise & Fitness Logo
427 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
