Question about LEC Refrigerators
Turn down temperature model df112g
Wine cooler
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
  • 218 Answers
SOURCE: wine cooler
Try this website. http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=224777abd6c75c24622a757a6f5ff1ba&q=Magic+Chef+MCWC30MCG&e=1
Posted on Jul 27, 2008
SOURCE: Oster wine cooler (peltier diode)
I called the contact in one post below, and he was VERY helpful. Took all my info, submitted to the division handling this and they overnighted me a check for the entire amount plus tax for the wine cooler to me! Call Jason!
Jason's contact info is:
Jarden Consumer Solutions
2381 Executive Center Drive
Boca Raton, FL 33431
(561) 912-4100
Posted on Oct 02, 2008
  • 19 Answers
SOURCE: Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Posted on Feb 21, 2009
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
I have a igloo 48 bottle wine cooler, and it will show error code "LC" and then you can not adjust the digital temperature or turn the light on. It fridge still feels code? Any ideas would be great!
Could be the temperature sensor. There should be a support number in the manual you can call. Hope you can get it fixed. if not check out my blog for help choosing your next cooler. The Best Wine Coolers The Complete Guide Vino Coolers
Jun 07, 2016 | Furniture
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Refrigerators Logo
Top LEC Refrigerators Experts
mike cooper
Vernon Taylor
Are you a LEC Refrigerator Expert? Answer questions, earn points and help others
