Whirlpool wahsing machine has stopped mid spin and is flashing 'F13'. Have lost manuel, what does this mean?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 10, 2012
  • 2 more comments
  • Bethan James Dec 10, 2012
    AWOE8759B
  • Richard Roth
    Richard Roth Dec 10, 2012
    Unplug the unit, open the top and reach down and check the wires on the door lock. Wiggle them around to be sure you have a good connection and plug it back in and try it. Keep me posted!
    Its working! You are a genius! Thanks very much.
  • Richard Roth
    Why thank you! Also, thanks for using FixYa!
futureloginn
  • 734 Answers
SOURCE: Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Dec 10, 2008
    • 4 Answers
    SOURCE: Whirlpool AWM8121 stops working mid
    Fault code 3 = Drain failure or not detecting empty drum.
    Check pressure switch, blocked drain, drain pump.
    See link below for service manual.
    http://www.user-manuals.com/advanced_search_result.php?keywords=857081253000&forward=plist
    Posted on Dec 15, 2008
    vickygomar
    • 460 Answers
    SOURCE: washing machine stops mid-cycle
    F30
    DISPENSER SYSTEM ERROR
    when the dispenser motor cannot be driven to its proper positon.
    ==========The following information is for a TECHNICION SERVICE(only)========
    1.- Unplug washer or disconnect power.
    2.- Check mechanical linkage from dispenser motor to the top of the dispenser.
    3.- Check wire hamess connections to the dispenser motot and Central Contol Unit(CCU)
    4.-Check dispenser motor for power rotation.
    Was this helpful?
    Posted on May 12, 2009
    Hit it again
    • 13 Answers
    SOURCE: Whirlpool AWM 6100/s - stopping
    Yeah. This is a pump problem. Our machine first did this about 3 months ago. I took the filter plug out and removed about 10 coins from around the pump impeller area! I removed the pump and dismantled it. Unfortunately water was getting in past the seal on the pump spindle. I cleaned it all out and reassembled it. Worked fine till a couple of weeks ago. It has worn out the spindle "bearings" and because of the loose play it gets stuck, intermittently. If you are by the machine when the drain cycle starts , you can give the filter housing a few bangs(take off the circular cover) . The pump will start up .It makes a grumbly sound, as it is knackered. But once started will generally keep going.The answer however is a new pump. And probably a pact with everyone in your household to be more careful not to leave stuff in the clothes you put in the machine. Our washer has got through 2 mobile phones. a packet of bradding nails, a lot of cash, both coins and notes.Various other stuff that i wont mention! The pump gets very hot when it is trying to turn but cant because of debris on the impeller. This will lead to the pump failing after a time.
    Posted on Jan 27, 2010
    SOURCE: my washing machine which is a whirlpool 6th sense
    The problem has to be in the water distribution (dispenser), that has an electric motor.
    Posted on May 27, 2010
    Doesn't work. Why does it stop mid-cycle?
    washing machine stopped mid cycle, won't drain : DIY - Reddit
    https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
    RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
    Troubleshoot - washer stops mid cycle, won't drain or spin ...
    ? 1:58
    https://www.youtube.com/watch?v=6Gc0ZgLD6a4
    Jun 20, 2012 - Uploaded by searspartsdirect
    Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
    Washing machine stops mid cycle - White Goods Help
    www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
    Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
    Why does my washer stop half way through cycle - Ken
    Dec 18, 2015 | Washing Machines
    Whirlpool awoe 8548
    The f13 is a door lock error. You will need to replace the door lock mechanism, could also be the wiring or connections for the lock itself so check that first. Cheap part and easy to replace.
    Jul 08, 2013 | Washing Machines
    Stops mid cycle and the 400 and 0 spin lights flash
    According to the service manual ( which you can download ) it is the fault code 05 which means NTC failure. This is the water temperature sensor.
    Feb 17, 2013 | Whirlpool AWM6120 Front Load Washer
    I have the f13 error, on whirlpool duet ht, 9150. I have removed the top and I'm trying to run a drain and spin. The motor seems to work fine as it cycles through all four steps, but never seems to...
    F13 codeindicates that the dispenser motor is not able to be driven to it's properposition.
    *Check mechanical linkage from the dispenser motor to the top of thedispenser.
    *Check wire harness connections to the dispenser motor and CentralControl Unit (CCU).
    *Check the Dispenser Motor.
    Toremove the error display, press Pause/Cancel twice. IfPause/Cancel does not work: *Unplug washer or disconnect power for oneminute.
    *Plug in washer or reconnect power.
    *Re-select the cycle and press Start. Hopethis helps.. Good luck! :)
    Jun 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
    my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
    Mar 15, 2010 | Whirlpool Washing Machines
    Washing machine stops mid cycle and lights start flashing
    Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
    The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
    Hopefully this will solve the problem.
    Plz rate this solution.
    Thanks.
    Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
    Duet Sport stopped in mid cycle
    Read the Manuel and see if they offer an over ride, first.
    Since you already tried rebooting the machine, I won't suggest that!
    If no go you will need service at this time!
    A&E Factory Service is nation wide!
    1800-905-9505
    They are open 7 days 24 hours to make appointments
    Neil
    Jun 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Bosch Excel 1200 wahsing machine, when trying to activate spin, it shows the normal 10 minutes, but then goes straight from 8 mins to 1 min and items arent properly spun
    bosch exxel 1200 washng machine
    has error message 04 and wont drain or spin
    can you help?
    have lost instruction book
    Mar 27, 2008 | Washing Machines
    Washing machine stops mid cylcle
    try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
    May 10, 2007 | Whirlpool AWM6120 Front Load Washer
    Washing Machines Logo
    218 people viewed this question
    Top Washing Machines Experts
