Question about Craftsman Snow Blower / Snowblower Bottom Cover :
How do i change the drive spring on my craftsman 4/21 snowblower
The spring going from the drive pully to the frame broke on my craftsman 4/20 snoblower I cant figure out how it goes back in I found the spot on the frame but it rests on the large pully there must be a different way it sits in there
  • Kim Walton Dec 18, 2012
    yes the long skinny spring
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Is that the spring under the plastic hood behind the snow throwing shoot?
Posted on Dec 11, 2012
How do I fix my snowblower when the wheels won,t move ahead or back
Sounds like gear on axle shaft broke shear bolt or key. Take bottom plate off base of snowblower.It is ok to tip snowblown up on front end so wheels are in air. After plate is off turn wheels and see if drive gear is moving with axle. If not key way or bolt has broken off, replace and will be back in motion.
Feb 18, 2015 | Craftsman Snow Blower / Snowblower Bottom...
No drive gears
ok ther is clutch Disc and it,s worn out need to replace it or the drive gear is worn look for broken rubber ring
Feb 03, 2014 | Craftsman Snow Blower / Snowblower Bottom...
C950-52118-2 Belts
there should be like a idler pully which is held on by a spring and pully look on youtube most are the same setup
Jan 05, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Drive belt on deck keeps jumping off
The belt tentioner is loose.
Jun 22, 2013 | Craftsman Garden
I have a 2 yr old 8HP Craftsman snowblower. My small engine buddy picked it up in Nov to give it a tune up check the belts etc..I had been doing yearly maint on it but wanted to see how he busted it apart...
Are you trying to move the gear selector with the engine off? This is a friction wheel/disk transmission and the friction wheel usually will not move on the drive disk without the engine running.
If you have the bottom cover off, lift up on the drive wheel. (The rubber wheel. Lift it off the drive plate) It has tension on the plate using a spring. The gear shift lever should move then.
If it won't move check the sliding mechanism for the friction wheel and make sure it has a little grease on the shaft it slides on. Also check the cable and the pulleys the cable runs in. Sometimes the engagement cable (forward drive lever on the handle) falls off the pulleys. Sometimes these little pulleys will break.
These Craftsman snowblower transmissions are all basically the same. Here is a manual that shows the drive system.
http://www.managemylife.com/mmh/owner_manuals/23825/CRAFTSMAN-Snowthrower-Gas-L0909129?brand_name_search=craftsman+88970 Look at page 20, figure 22.
Let me know if you have any other questions or you need more clarification.
Jan 10, 2011 | Craftsman Garden
20 Hp 42" Deck Lawn Tractor: I have a craftsman rider that starts idels and dri...
sounds like one of the pullies is locked up . check all the pullies for free movement the plastic pullies are junk. replace with metal ones if you find a bad one.
May 17, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman Snow Blower / Snowblower Bottom Cover : Logo
170 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
