Question about Kenmore HE2 Plus Front Load Washer
KENMORE WAHER CUTS OFF WHEN PRESSING START BUTTON
POWER TURNS ON, WHEN I HIT START BUTTON POWER CUTS OFF AND MUST HIT POWER BUTTON TO CUT BACK ON, HIT START AND SHUTS BACK DOWN
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 10, 2012
  • 1 more comment
  • PHILIP WYNN Dec 10, 2012
    110 47571603
  • Richard Roth
    Richard Roth Dec 10, 2012
    OK, on that model you will need to replace the CCU. Here is the part to order.http://bit.ly/TPMnl7 To replace the part, just remove the top and you will see it there.
  • Gayle McIvor
    Gayle McIvor Apr 24, 2014
    HI there, I am now having this same issue with my Kenmore HE2 Plus Front loading Washer... I am unsure of the complete model number.. it is a 110.4751.. i dont see how I would remove the top of my washer though? Where would I find the complete model number? thanks!
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: shuts down when start button is pushed
There is likely a short on the ECU and it must be replaced. Further testing should be conducted by a professional in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 10, 2010
Ninja Blender 1100 starts then stops almost immediately, is there a way to fix this?
It Could Be a Number of Things..
It's most likely that the electrical Wire Could Have a Shortage, If it cuts off again Try gently Wiggling the Electrical Wire in a Number of Directions If it cuts on and off while your fidgeting with it, you've found your Problem! A quick fix would be to Adjust the wire In the position it would cut on the strongest, wrap the cord with Tape to Keep the wire in that Position, this will Prevent it from shorting again.
Either that or you simply put too much product in the Blender with an inadequate amount of liquid.
Jan 04, 2014 | Blenders
Tip
Setting Your DishNetwork Remote Control
With Device Powered On, Press and Hold Mode Key (Tv, VCR, ETC) Until all lights across the top light up, release the mode key, press the large power button, (not the one that says tv), then start pressing down on the remote until the device cuts off. when it does you can hit up to go to the code before it and then hit down again to confirm the code works, then press # which is the search key, if programming for TV press the TV Power Button and your Set should Come on.
on Dec 15, 2009 | Audio Players & Recorders
Why wont my asus tablet turn on
Try this: press the power button and the volume UP button at the same time, then release at the same time. The recovery menu should appear when you release the buttons. Sometimes it can be a little finicky. Try to make sure you're pressing the buttons exactly at the same time. I think it can work as well if you press the volume UP button first, and then the power button immediately after, holding both down at the same time, then releasing.
If all else fails, take off the back cover and disconnect the battery from the main board for 20 seconds. Re-connect the battery and try above again.
Post back if succefull or for futher help.
J
Dec 09, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Model number p46151wk, can turn tv on with power button but automatically turns back off
A number of possible answers---I need to know two things= on back of set aside from model number is there a chassis number like PTK 195 etc? Is power light green and going off or remains on?
Aug 27, 2012 | RCA P46924 46" Rear Projection Television
AFTER NOT USING MY HITACHI C10FSH FOR A YEAR OR SO. I TURNED IT ON YESTERDAY AND I HIT THE TRIGGER AND IT STARTED, I THEN SET UP MY CUTS AND IT WOULD NOT START. AFTER CHECKING THE POWER SOURCE, I PRESSED...
with the tool unplugged check that the two carbon brushes are free in the holders . remove the two caps locking them in and take them out , blow out and replace . be careful make sure when putting them back in that the caps do up nice an free. possibly dust stopping brushes from making contact to armature .
Aug 16, 2011 | Hitachi C10FSH 10" Dual Bevel Slide...
CAR DOESN'T START, I HIT A BUMB AND THE CAR SHUT OFF, WHEN I TURN THE KEY NOTHING HAPPENS, RADIO, LIGHTS COME ON
Some vehicles have a fuel pump cut off switch that shuts all power to fuel pump in case of an accident. It activates by inertia...meaning that a severe "bump" will activate switch, thereby cutting off the fuel pump. If your vehicle has that switch, hitting that bump may have activated switch. If you do have that switch, reset it by pressing in the reset button.
Jul 04, 2010 | Chrysler Sebring Cars & Trucks
URC 3220 REMOTE
just try to program the remote by hitting code search on the remote and then continuously hit the power button until the tv turns off and then cut it back on and the tv should be programmed, good luck! make sure that you press and hold the code search button until the light comes on and then the power button.
Feb 01, 2009 | One For All URC4110 Remote Control
Kenmore electric dryer model 110.60942990 The dryer cuts off intermitingly and I need to press the start button to start it again. Then it could run for 20 minutes or more with no problem or it could cut...
i think model may have what is known as a even heat control possible it may be bad or motor relay just to right of control motor relay is the one with blue wires switch the heat relay the one with big red wires with it to verify to acess both remove screws under end cap..they just pull off.. and lift console up and back
Jul 29, 2008 | Dryers
Kyocera kx2
i know its been long since uve post this did u try plugging it in and lettin that turn it on then hitting the power its worked for me when it has frozen on me
Sep 12, 2007 | Kyocera KX2 Cellular Phone
Kenmore HE2 Plus Front Load Washer Logo
281 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
