Question about Philips Magnavox 20MS3442 20" TV
Magnavox Model 32mf369b/f7 volume stuck on down
    Top Expert:
  • Philips Master
  • 14,553 Answers
If the volume constantly by it self lowers with display on screen of that--the vol down micro switch under the vol down button is doing this--if other let me know.
Posted on Dec 10, 2012
Volume on magnavox model 50mf412b/f7 going down on its own.tips?
Disconnect the control button strip. If that clears the fault, you have found it.
Oct 13, 2017 | Magnavox Televison & Video
Power problem
THIS IS NOT A POWER SUPPLY ISSUE PLEASE REPLACE MAIN BOARD THEN YOUR PROBLEM WILL BE SOLVED .
THANKS
Jul 28, 2013 | Magnavox Philips 32MF369B/F7 LCD TV, 32 -...
Magnavox 32mf369b/f7 sound occasionally decreases by itself, as if someone pressed the button
The volume button must be smashed in,dirty,or defective...I would try pressing the volume- several times repeatedly..maybe try cleaning it with a can of air.
Nov 28, 2012 | SNK Magnavox 32MD357B_37 32 in. LCD...
Problem with volume level
Look for any jammed button on panel or on remote. Look for loose contacts at rear. Remove batteries from remote and check. Try changing the input device to something that you are sure, works.
Jul 28, 2012 | Magnavox 26mf330b/f7 26 Hdtv, 720p Lcd...
I have a Magnavox 32MF369B/F7 TV. When I turn it on, it just scans inputs over and over but never detects anything. I have plugged various items in. Help?
It sounds that the memory IC to your TV is faulty. This is a very samall IC, have ony 8 solder terminals. Even though it is physically a small one, function to it when the TV works is great. It stores all the input and system data. It is a non-volatile type [means, even the power to it is switched Off, the stored memory in it wont lost] It is also called as an EEPROM [Electrically Erasable Programmable Read Only Memory]. This IC can be located very near to the main system control IC on circuit board. Replacing it is a skilled work. If you are not handy, seek tech support to replace it. It is an easy to get part, can be bought from most of the electronic spare pat selling shops at your town. Very cheap to buy too. But replacing it is a skilled work indeed.
Jun 20, 2012 | Magnavox 22MF339B F7 22 in HDTV TV
1994 magnavox tv stuck in demo mode. Model#TS3270B101
With the set ON. Press the volume up AND volume down at the same time. OR
Press the channel up AND channel down at the same time.
Oct 01, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a 32 inch MAGNAVOX LCD TV that exactly half of the screen has a gray or white film in front of the picture but the picture can still be seen behind it. The other side of the tv screen is perfectly...
This problem is the cause of the T-CON board is dying.This T-CON board sit at bottom of the LCD screen right in the middle of LCD screen.Change this T-CON should solved ur problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 05, 2010 | SNK Magnavox 32MD357B_37 32 in. LCD...
TV is 1995 Model 25TRC1-0101 Magnavox. Seems to
The tv has been accidentally set for "demo mode". Press the volume up and volume down buttons in front of the TV at the same time for about 5 to 10 seconds untill the demo disappears or sometimes the TV will turn off. You should regain control of the TV after this.
Jul 19, 2010 | Philips Televison & Video
Magnavox tv is stuck in demo mode or something. It is from the 90's. I don't know the serial number off hand, but I need to get it out of demo mode. I tried the volume up volume down buttons. I can...
If you can find the model number (probably located on the back of the TV) you can go to the magnavox website at www.support.magnavox.com and search for your model number. They have troubleshooting tips and tricks for a lot of common problems. You may need to speak with a representative directly to help solve your specific problem. After you find your model on the website, you can download the user manual from the left panel, which may help as well.
Dec 05, 2008 | Televison & Video
Magnavox television stuck in demo mode
My wife somehow put our Magnavox TV into demo mode too...
Plug in the set. With the set ON. Press the volume up (+) AND volume down (-) at the same time.
This worked to get it out of demo mode!
Jan 03, 2008 | Televison & Video
Philips Magnavox 20MS3442 20" TV Logo
222 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
