Question about Radio Communications
Cobra 29 wx nw st does not have full RX
This radio was given to me almost a year ago. It works OK, but not to it's full capacity. I've had it peaked and tuned. SWR is at 1.2 on ch. 1 and 1.4 on ch. 40. I had been noticing that trucks I was sitting next to could hear trucks that I couldn't. The trucks in question were well within range for me to hear, but I couldn't. Sometimes opening the gain and squelch all the way would allow me to hear them. A couple of weeks ago the back light on my meter went out (I know it's not needed, just wanted it.) Anyway, when I took it to a local CB shop, he checked the radio out for me. He said I'm only receiving about half of what I should. I'd like to fix it myself, just can't seem to find the information I need to get the job done.
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
Go towww.cbtricks .com and look up cobra 29 wx nw st everything you need to know is there. you would be better off taking it back to the tech and having him do the receive because you would need more meters than just the one one the front of the radio.
Posted on Nov 04, 2013
informatica
  • 1114 Answers
SOURCE: Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 31, 2008
audio20
  • 22 Answers
SOURCE: swr meter not moving.
If the radio is working don't worry about the meter unless you absolutely want it. These little meters are not very accurate or reliable. Get an external SWR meter to check the antenna.
Posted on Apr 23, 2009
  • 36 Answers
SOURCE: i have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Posted on Jun 15, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Cobra 29 SWR, cal meter
Hello there:
Rule of thumb is go by what the manual tells you. providing it is the manual that is for the radio.. that is why they make manuals for that particular radio a 1-1 to a 1-2 swr rating is really good providing you have no saturation on the internal filter. over saturation due to swr being set too high will eventually burn out the finals of a radio
i have delt with radio's for about 17 years now so i really suggest consult the users manual and always use only a authorized dealer for that particular radio just like my cobra 2000 i am not going to send it to a shop that just does radios i want a authorized cobra dealer ok i hope that this really helps ok please dont forget to give this solution a rate for me it helps me out so i can continue to help out others like yourself.
best regards
MICHAEL
Posted on Aug 23, 2009
  • 38 Answers
SOURCE: I am a new Truck Driver and I had given to me a
I have the same radio as well. If you are running a "stock factory mic".....do this:
VOLUME: set to your comfort
SQUELCH:all the way to the left (if you don't mind hearing everything other wise adjust to the right to illiminate noise)
DYNAMIKE:If you have a factory mic or "noise canceling mic", turn all the way to the right (unless it squeals and then turn the mic gain down slowly until the squealing stops)
RF GAIN:that is your "receive" and I always turn it all the way to the right to maximize reception! In my opinion, this is the dumbest knob ever made since why not hear as good as you can??? thats what the SQUELCH is for!
DELTA TUNE: IT IS "USELESS!!!
SWR CALIBRATE: don't ever trust it! ALWAYS USE A GOOD SWR METER "IN LINE"
Now as for the "SWITCHES"
The top left switch is the SWR and as I stated, do NOT trust it and leave it on "S/RF (TOP)
SWITCH TWO: If you have it on OFF, you may get allot of engine spark plug firing noise so I run mine in the "middle" (ANL)
THIRD SWITCH: CB
FOURTH SWITCH: Brightness is to your liking!
There ya go! You can always set the switches to your liking and comfort.
"WILDCAT" IN LAURELVILLE OHIO
Posted on Dec 30, 2010
Cobra 29 wx nw st how to increment modulation
Clip D-11 .diode 11 .this is the modulation limiter .
Jan 30, 2014 | Cobra 29 WX NW ST 40-Channels Base CB...
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
What size inline fuse is in the cobra 29 wt nw
Usually a 3 amp quick acting 3AG fuse---do not use the generic ones from Radio Shack.
If the radio got hooked up backwards look and test for a dead short across the power leads-----there is a diode just inside where the hot lead goes that will be shorted .
SD TECH
Apr 21, 2012 | Cobra 29 WX NW ST 40-Channels Base CB...
My cobra 29 wx nw st can recieve, but will not broadcast
Could be anything from a broken microphone wire to a bad final or regulator.
Sep 11, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Twilli811@hotmail.com
check the SWR's on antenna. check microphone it has to work for the RX to be heard. cbshop
Sep 06, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Echo on a cobra 29 nw
When you purchase an echo board, the instructions come with them.
If you need any help, don't hesitate to email me at rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Aug 25, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Codra 29 nw ltd classic
For the money,the Cobra 29 nw/st is just as good if not better than a Galaxy. Cobra is more durable by far. I have had 3 of these cobra's in the last 30 years. Only had to replace the last one because the tractor got hit by lightning.
Sure would not pay big money for a name.
Mar 19, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Mar 12, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio Communications Logo
51 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
