Whirlpool 6th sense keeps blowing fuse in plug
Blows fuse in plugafter a few washes
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 10, 2012
  • joseph brown Dec 10, 2012
    HI, its a Whirlpool 6th sense antibacterial AWO/D 5716
ginko
  • 19396 Answers
SOURCE: my washing machine keeps blowing he fuse in the plug
That means that there is a short or a contact inside the machine.
The short can be on power cable, on control panel, on in the internal wiring harness.
Posted on Apr 13, 2009
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
  • 2468 Answers
SOURCE: My washing machine is blowing my fuse!!
either the motor start capacitor on the machines motor is shorted,the motor winding itself is grounding itself out to the case and shorting or you may have a bare wire touching the metallic frame in the machine
Posted on May 14, 2010
SOURCE: I have a whirlpool 6th
f13 is a problem with the door lock, I have the same machine and it takes 4 minutes for the door latch to open and if it dont in the 4 minutes F13 comes up and the machine will go off and not start again.
Posted on Oct 21, 2010
TheMobilian
  • 8220 Answers
SOURCE: whirlpool 6th sense washing machine,
Find your machines tech sheet. The error codes and suggested remedy's will be there.
Posted on Feb 01, 2011
Whirlpool 6th sense washing machine
All washing machines have a water level sensor, this can be a tube into the drum that leads up to a switch normally attached to the inside higher up, what happens is the tube gets clogged up with muck and gives a false reading, which needs cleaning out.
Another problem may be your input valve normally a sngle cold water input, the valve can get clogged with limescale and its just slow to switch off even when the power is off. The default is a closed position.
Try switching the machine off at the plug as soon as it finishes, if it starts filling up its the input valve, these can be under twenty pounds on popular auction websites.
May 11, 2014 | Whirlpool Washing Machines
Whirlpool 6th sense wont start cycle
I have the same problem. Look at the previous post, it seems to be the motor brush worn out. I've opened up the machine and checked. The carbon brush remains very little. I am trying to find out a replacement brush
Dec 27, 2013 | Whirlpool AWM6100 Front Load Washer
Whirlpool dryer 6th sense awz3413
Ok has your element got continuity? could be a thermal fuse or element.or your 220 do you have a voltage meter? heres a link that might help you..http://www.youtube.com/watch?v=HRKIU4LiS20#t=109
Dec 04, 2013 | Dryers
HI, WE'VE GOT A WHIRLPOOL 6TH SENSE WASHING
washers are very expensive to fix they cost more to fix then to buy
Aug 09, 2013 | Whirlpool Washing Machines
Whirlpool 6th sense - pump issue
The drain pump probably just needs cleaned. If you've never cleaned it i can direct you to videos that are step by step. Let me know.
Jan 20, 2013 | Whirlpool Washing Machines
Whirlpool 6th sense Finished wash, then noticed strange read out on front with red ? it said f13. Cant find trouble shooting manual,then i turned dial to off position now no power to machine, Changed fuse...
In my list for Whirlpool, 'F13' stands for 'Dispenser circuit error' - requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 01, 2011 | Whirlpool Washing Machines
Its a whirlpool 6th sense washing machine no awd/d 5706, it stopped with a full load in 8 minutes before end time no numbers are flashing up but it wont do anything , i have opened the door took washing...
i have a whirpool 6th sense washing machine and it wont spin and the timer stays on 14 minutes remaining have you come across this problem and do you have a cure
Jul 29, 2010 | Whirlpool Washing Machines
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
