Question about 3Com OfficeConnect TP800 Networking Hub
What is the IP address for the OfficeConnect TP800
    Problem Solver:
  • 18 Answers
Open door trim,sprayed rust off spray through cam &its attached parts &try to close &open constantly
Posted on Dec 10, 2012
  • 1 more comment
  • Rakesh anegirikar Dec 10, 2012
How do I configure the OfficeConnect TP800
There is nothing to configure. Hubs simply spit a network connections almost like a TV cable splitter divides cable for separate rooms.
Hubs require a router that manages the network by providing IP and other network management tools.
Dec 10, 2012 | 3Com OfficeConnect TP800 Networking Hub
I cannot connect to my 3Com OfficeConnect Wireless (3crwps10075-us) Print Server 3crwps10075
Check you firewalls. Sometimes you will have to allow certain mac addresses or certain ip addresses (may be less secure than the mac address), then change sharing level to full, before things begin to work.
Please post back and let me know if this helps!
Feb 21, 2012 | 3Com OfficeConnect Wireless...
How do I connect to 3com officeconnect dual speed switch 8 plus
on a mac u have to go to finder, applications, uttility, network utility and in there under the info tab there is a drop down. in that drop down you have to choose network interface (en1) AND IT GIVES YOU THE IP ADDRESS
Jun 04, 2009 | 3Com OfficeConnect Dual Speed 16 Plus...
I can't change the http://192.168.1.1 to something else
you tried changing ip when the modem isn´t connected?
can´t you turn the inbuild router off from modem setting?
May 25, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
3com 8 port hub not connecting to 2nd pc
Be sure that when you say its a hub that is indeed a layer 1 device which is just passing the signal and data along to all ports. Be sure to check the cable on the second device. At this point it must a straight cable you use to connect the PCs to the Hub. PCs transmit on pins 1 & 2 and Receive on 3 & 6. Hubs are the opposite. So a crossover will not work. You need PC pin 1 & 2 Tx to Hub Pin 1 & 2 Rx and over to PC pin 3 & 6 Rx to Hub pin 3 and 6 Tx. Tx = transmit and Rx = Receive. Also assign an IP address on each machine that is in the same subnet as each other. Such as PC1 192.168.1.100 mask 255.255.255.0 and PC2 IP address as 192.168.1.101 Subnet Mask 255.255.255.0 This way the 192.168.1 is the same for 8 PCs and the only change is the last number (octet). Also keep the speeds at either 10/100/1000 what ever the product is rated for but always keep the duplex half. Half is good because on a layer 1 hub, everyone is broadcasting at the same time. So you have to have half of all the ports listening at all times.
I hope this helps. My advice is to buy a layer 2 switch.
Mar 18, 2009 | 3Com OfficeConnect TP800 8-Port Ethernet...
OfficeConnect Router Web Admin screen open to all
I'm not sure how 3 com routers work but I work with Linksys equipment and Actiontec a lot. Their systems have a toggle in the admin setup to disable remote access. If that is turned off and the admin needs a password to get into it, you should be fine.
Aug 05, 2008 | 3Com OfficeConnect Router
3com officeconnect wireless 11g cable/dsl router
router default ip gateway will be the 192.168.1.1,so you can able to give the same ip address,so you configure only other ip address & try it.
May 25, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Network Hubs
please log on to www.youtube.com for your clarification there you can get an clear idiea about everything..
Dec 15, 2007 | 3Com OfficeConnect TP800 8-Port Ethernet...
Limited or no connectivity
you need to get into the routers settings (192.168.1.1 in your web browser) and look for DHCP, and enable it so as to give your pc's there automatic ip addresses, also check in the general settings if it's a modem router that you have got a internet connection from your ISP and all the dns and ip addresses are showing. Go to the properties of each network card in network connections in your control panel and click on the TCP/IP line and click properties again and ensure obtain ip address automatically is selected and click ok. Restart all pc's if neccasary and refresh your web browser when trying to get online.
Sep 06, 2007 | 3Com OfficeConnect Router
3Com OfficeConnect TP800 Networking Hub Logo
74 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
