Question about Dryers
Want to replace worn parts on dryer
Where is it best to buy them and get instructions for their installation, if so
    Top Expert:
  • Dryers Master
  • 14,553 Answers
Best place to start would be with the Model number and Google---Google that with parts to locate sources and then with other keywords depending on what you are after.
you can shop online for almost anything and Google only takes some effort and time---begin searching.
Posted on Dec 10, 2012
Howh do i replace the gasket pad
Nancy,Could not find instruction for seal removal on your particular model, did post links to models, hoping they will be close/same as yours. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Door Seal part WP3405245 How To Replace
How To Replace Torn Or Worn Out Dryer Door Seal
Dryer Door Seal part 33002094 How To Replace
Jul 10, 2016 | Maytag MDE2400AYW 24 High-Efficiency...
Will not spin
Sounds like a broken drive belt. Below is a video showing step by step instructions on replacing a worn or broken drive belt. FYI, most Kenmore dryers are manufactured by Whirlpool and the parts are interchangable.
Best of luck!
Greg
Dec 28, 2011 | Kenmore Dryers
My GE Dryer works, but when the drum turns it makes a loud squeaking noise. Sometimes it is worse than others. Is there anything I can do to stop the noise or is it a sign that the belt is going. The...
It could be several things.
Your dryer uses nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Here is a video at this will walk you thru the replacement and inspection of the front bearing and glides. It may be a different model but the process will be the same. The blower wheel is another common place to hear noise and this is easy to check and inexpensive. The idler pulley is another part that frequently fails. Your dryer supports the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. All of these parts are inexpensive and easy to replace. There is a video of this also at the same site. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Oct 13, 2010 | GE Dryers
Dryer makes awful squeaking noise when running.
Bearings on Rollers are worn out, also felt seals could be worn out. You can buy replacement parts at appliancepartspros.com Put in you model number and it will bring you to full schematics of your dryer. You can also order the parts from them, good pricing.
Sep 27, 2010 | Maytag Dryers
The dryer is making a loud scratching noise while driving
Sep 17, 2010 | GE DBSR453EBWW Electric Dryer
Dryer motor noisy, service call said bearing are shot in motor, replace motor is as costly as new dryer all most. Where can I order new motor best buy as neighbor can install motor( Doctor electrical...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Yes, that is not that hard to fix and you can easily buy the parts yourself online...<br /><br />Here is a tip that will help you with the online buying...<br /><br />How to Buy Appliance Parts Online<br /><a href="http://www.fixya.com/support/r3907570-buy_appliance_parts_online" target="_blank">http://www.fixya.com/support/r3907570-buy_appliance_parts_online</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | GE Profile Harmony DPGT750EC Electric...
Dryer squeeks when drum is turning,gets very loud after about 10 minutes
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing assembly does not fail often in this type of dryer. There are videos of the testing and replacing of these parts at http://appliancehelponline.com/dryerrollervideo.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there. All parts come with installation instructions. Not all models are available.
Jun 09, 2010 | Whirlpool LER4634J Electric Dryer
Drum squeaking noise
Jun 08, 2010 | Whirlpool GEX9868J Electric Dryer
Dryer is noisy especiallly after start up.
Jun 01, 2010 | Whirlpool LEQ9030P Dryer
Dryer problem
You need to replace the rear drum bearing, and also the plastic bearing pads at the front of the dryer, where the drum goes round against the front panel.
There is a repair kit that contains all the parts you need to carry out this repair, with instructions on what to do.
P
It does involve stripping the dryer down to complete these repairs.
Jan 23, 2009 | Zanussi TC7102W Electric Dryer
Dryers Logo
Top Dryers Experts
