Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Maytag LSE7800ACW will not perform "rinse" cycle.
The washing machine will perform all other cycles without any issue, but when the timer gets to the rinse cycle, it just stops. I have to manually skip to "spin" in order to get the washer to drain.
  • 1462 Answers
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Posted on Apr 25, 2007
Buffalo12980
  • 625 Answers
SOURCE: stops on rinse cycle
I know how frustrating it can be but seems like the cam drive inside the timer is not advancing. I wouldn't advise taking it apart but that's your call. Was the no rinse problem your main reason for changing the timer in the first place? all seems to point towards the timer - still. chain of events: start, timer advances one step, solenoid opens for water, tub diaphagm closes, starts timer again, machine agitates, timer stops agitate motor off, timer advances to spin, drain, motor reverses, pump on. timer stops, advances to next step. RINSE opens solenoid. Here's the problem. Could be the timer contacts are not making up completely giving you full voltage to fully open the solenoid valve. the solenoid is a magnetically operated device. NOT full voltage will make it buzz. inside is an iron slug that is acted upon by means of magnetic force from the coil. Still it all points to the timer. Yeah I know they're not cheap. :(
Posted on Sep 15, 2007
SOURCE: Maytag Atlantis MAV6200AWW; Washer goes through
Maytag Atlantis washer goes thruout washing cycle,but dosen't simse or spin....
Posted on Jun 12, 2009
eeevaaa
SOURCE: Maytag washing machine skips rinse cycle
I found this problem with mine intermittently and it was because i had filled the machine too full that it was too heavy to initiate the spin. maybe try a lighter wash?
Posted on Jul 05, 2009
SOURCE: My Zanussi ZWF 1221 W will not rinse. Any ideas?
my zanuzzi 1500 will not rinse
Posted on Aug 22, 2009
I have a Maytag Performance series washer. Model MTW5740TQ0. It agitates during Wash cycle, but will not spin during after the Rinse cycle. It does this more times (95%) than not, but not everytime.
It may be falsely sensing water in the tub. Do you hear the pump running after the rinse (trying to pump out water that isn't there)? This would indicate a fault in the water level sensor. Does it seem to sense the water level correctly after the wash cycle? It could also be a timer problem.
Feb 01, 2017 | Maytag Washing Machines
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
Maytag washer stops after wash cycle for long periods of time
Good day,
If the issue your describing occurs all the time then being brand new it's a warranty issue. It will be covered free of charge.
Call your selling dealer for details on getting a free warranty service call. Sounds like either a motor problem or timer issue, but it's not your problem.
Jul 05, 2010 | Maytag MVWB300W Top Load Washer
Maytag SAV5910aww will not always drain. Fills and agitates fine but will go through entire cycle without draining. Will sometimes give end of cycle buzz sometimes not. If I am in the room and lift the lid...
"I have found spinning the timer back to begining of rinse cycle first helps". The timer only rotates clockwise; counterclockwise rotation can destroy it.
May 18, 2017 | Maytag SAV5910 Top Load Washer
Machine not functioning
HI, this is a damaged timer device. the mechanism has failed and , it is unable to correctly initiate the proper washing cycle. simply replacing the timer/control will fix this issue..
Jun 03, 2009 | Maytag Dishwashers
Will not do rinse cycle
This is a early warning of timer failure. it will fail soon. you will need to replace the timer control device on this unit. this will correct this issue you are experiencing.
May 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Matayg Atlantis Washing Machine gets stuck in the Rinse Cycle and will continue to rinse for hours.
This is the sign of a bad timer. It is not sensing how long it has been in the cycle. The timer is not advancing. Replace the timer.
Feb 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag A408S washing machine does not complete deep rinse cycle
I ordered/waiting for a new timer as suggested, and hopefully this will fix my problem. I will post a response after I get the part.
Nov 13, 2008 | Maytag Performa PAV2200
Maytag Neptune MAH4000
Are you getting cold water to fill ?How is the water pressure?Timer maybe at fault here.
Jun 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
61 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
