Royal adding machine 770 HD EZVUE paper feed
The paper feed on my Royal 770 HD is stuck it will not feed the paper it will add # on top of numbers how can I fix this. Thank You! Bobbie
SOURCE: Paper will not feed into machine
Most likely the sensor in the insertion area is not recognizing a paper when you try to insert it to be shredded.
Try to clean out the gears, and oil the grinders.
Clean around the insertion area to remove any debris from around the sensor. (Be sure to turn it off/unplug it first!).
If you can remove the shredder head/grinders from the body of the shredder box, turn it upside down and clean it that way as well.
Sometimes the little pieces of paper get clogged up inside the gears.
I got some of the dust spray with the straw...inserted the straw deep into the shredder grinder/gears and sprayed.  I got tons of stuff out.
My motor/grinder worked perfect after I did all this.
Posted on Oct 30, 2007
SOURCE: royal 15mx
You probably have the same problem we do.....the unit vibrated some of the mounting screws loose, causing the gears to disengage slightly and then strip one of them (plastic).....hence, no movement of the shredder, even though the motor is fine.  I myself am looking to Royal for a replacement gear.  I don't want to have to buy another one and it beats throwing the whole thing out....what a waste!  Maybe they should start using some glue on the mounting bolts!
spanky_velo@yahoo.com
Posted on Jan 28, 2008
  • 133 Answers
SOURCE: Paper no longer feeds in. Motor works.
Please check the sensor is on or off.
if paper is feeding completely then it means you need to buy a new one.
Posted on May 23, 2009
  • 1218 Answers
SOURCE: I have a Royal VF1012mf shredder. It is making a grinding noise
Try putting some shredder oil in the throat of the machine were the paper goes to see if it loosens things up.
Posted on Aug 29, 2010
  • 1218 Answers
SOURCE: I have a Royal CX
The Royal cx-6 shredder is a small consumer shredder rated for "up to 6 sheets at a time" so yes it will jam with anything more that 6.
If running it in reverse won't work you will have to try to open it up and see if you can manually turn things to get the paper back out...there is no other way if it wont run in reverse...hopefully when you have the paper removed the machine will still function.
Posted on Oct 29, 2010
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Jun 13, 2014 | Sharp EL-2630P Calculator
Loading paper feed
really need more information. but look for a little door on the back/ bottom and check for a paper jam. do you hear the roller motor trying to pull the paper?
Apr 21, 2014 | Royal Ezvue 550hd Adding Machine
Royal adding machine 770 HD EZVue paper cutter
Here is a link to find the authorized service centers - contact the one closest to you:
http://www.royalsupplies.com/service-centers.html
Apr 09, 2014 | Royal Genuine Used 770hd Printing...
Paper won't feed
THROW IT IN THE GARBAGE1111111111111111
Apr 07, 2014 | Royal Ezvue 550hd Adding Machine
Loading paper into adding machine
REMOVE CLEAR PLASTIC GAURD, PLACE PAPER EDGE AT VERY BACK PRESS FEED
Jan 28, 2012 | Royal EZ-Vue Calculator
I need to RESET my unit because I changed the batteries kfs09@hotmail.ca thanx
The reset button for the ezVue 5 is on the back of the pull out qwerty key board. It is dubious that the ezVue 6 is different having the same form factor.
Apr 10, 2011 | Royal EZVue 6
We have a Royal EZVue 6600HD printing calculator. We were using it today and the paper stopped advancing. We took out the roll of tape and reinserted it according to the directions in the booklet. ...
The paper thickness may have something to do with it. Also If there is grit or other debris on the pressure roller, that can hinder the advancement too.
If there is debris (sometime you can not see the residue) remove the current roll, get stout paper towel or rag, and using isopropol alcohol, clean the pressure roller. Allow 5 minutes to completely dry, and try again.
good luck and don't forget to vote.
Oct 12, 2010 | Royal EZVue 6
Adding machine problems
Block yBob - did you ever get an answer to your problem. I'm getting ready to install an ink cartridge into the same machine.
Aug 20, 2008 | Office Equipment & Supplies
46 people viewed this question
jasbo
jasbo
