When cycle is complete cant get mashine started again
SOURCE: GWL11 completely Dead------blows main fuse when rinse starts
This is a poorly made machine with flaws that are never ending.My advice to you is save time and manly aggravation and get rid of this washer.
SOURCE: Fuse keeps blowing
This is probably a water heater problem Try operating on the lowest temp eg.15C If it goes through the cycle then its more than likely your water heater You will need a refit
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
SOURCE: Washing machine won't complete cycle
If it is a hot and cold fill washer, yes, then it could be a hot water problem related to the valve, or the water supply., if it is cold fill only, then the problem is elsewhere.
Pleas rate my solutikon.
Thanks.
