Question about Seiki 32" LED TV - SE321FB
Seiki half a white screen - Seiki 32" LED TV - SE321FB
Seiki 24" has audio but the display was complettly white bright
Hi, this is a failed IC on the board which overheats. Sometime if you leave the TV for a couple of days if might work after.. BUT it will eventually go white again. If under warranty or extended warranty then you can get it repaired.
Simple test is you get no Menu on the screen even though you press the remote Menu Button
Considering its size (24") I would not recommend a self-repair due to the cost involved.
Sep 27, 2016 | Seiki 24" Class 1080p 60Hz LED HDTV...
Seiki LE-55GB2 LCD TV. Have a blue screen and sound. Replaced the main board and t con board. Still didn't fix the issue. The white light are on in the back. What could be the issue?
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 28, 2016 | Seiki Televison & Video
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
Seiki flat screen less than two years old show white vertical lines and a bullet hole bleed in middle of screen. Charter cablebox and remote were giving trouble with on/ff and volume. Bought from Sea
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 14, 2014 | Seiki Televison & Video
Have 39 inch seiki tv have white lines vertical no picture
Aug 25, 2014 | Seiki Televison & Video
TV seiki .i have Seiki Se221fs ,the screen suddenly turn to white, but audio is still there. wondering anyone faced the same issue or any solutions? thx!
T'Con board fault. Do not transfer video signals to panel. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 05, 2013 | Televison & Video
My Seiki tv has a white screen
hi i am getting exact same issue , wondering what's your story ending? sj0982@hotmail.com ,share with me if you don't mind. thx
Apr 01, 2013 | Seiki 22" LED Widescreen TV SE222FS - CAM...
Seiki 32" LED TV - SE321FB Logo
79 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
ka4iup
ka4iup
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
