Royal 770 HD EZVUE paper feed it does not work when you are adding it over lapse the #
I have a problem with the paper feed it will not feed the paper it keeps printing over the same # what can i do to fix this.
5 Suggested Answers
SOURCE: Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Posted on May 11, 2008
flexion1
  • 737 Answers
SOURCE: Royal alpha 601 sc cash register
Hmm. That is almost NEVER a paper problem, so forget about that.
It is always difficult to diagnose head problems without seeing the machine.
It can be a dirty thermal head, but that's not common unless something has been spilled on it. If you want to try cleaning the head, open the printer, and find the head. It is usually a small aluminium block that clamps against the paper when the printer is closed. it will always sit against the front of the paper. On that block, you will see tiny lines all very close together. They go to a connector at one end, and a thin black line at the top of the head. Wipe this black line firmly with a dry cotton bud.
Here is a picture of a thermal head:
http://www.jarltech.co.uk/ger_new/new/pix/products/web/printhead.jpg
Just above the light brown strip, you can just see the black line. This is what you would rub clean.
Otherwise, make sure the paper is clamping hard against the head while closed. If the clamp is not pressing with the same force at both ends of the head, then you will miss some printing. Try pressing against the back of the paper at the head while it prints, and see if it prints any more than before, then you know if your'e on the right track.
Hope this helps.
Mark.
Posted on Aug 18, 2008
SOURCE: c3180 feeding paper but not printing
I ended up unplugging the unit for a few minutes. It fixed the problem...
Posted on Oct 01, 2008
Ajkill
  • 2035 Answers
SOURCE: brother laser printer wont print
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Posted on Feb 09, 2009
Loading paper feed
really need more information. but look for a little door on the back/ bottom and check for a paper jam. do you hear the roller motor trying to pull the paper?
Apr 21, 2014 | Royal Ezvue 550hd Adding Machine
Royal adding machine 770 HD EZVue paper cutter
Here is a link to find the authorized service centers - contact the one closest to you:
http://www.royalsupplies.com/service-centers.html
Apr 09, 2014 | Royal Genuine Used 770hd Printing...
Paper won't feed
THROW IT IN THE GARBAGE1111111111111111
Apr 07, 2014 | Royal Ezvue 550hd Adding Machine
Loading paper into adding machine
REMOVE CLEAR PLASTIC GAURD, PLACE PAPER EDGE AT VERY BACK PRESS FEED
Jan 28, 2012 | Royal EZ-Vue Calculator
I need to RESET my unit because I changed the batteries kfs09@hotmail.ca thanx
The reset button for the ezVue 5 is on the back of the pull out qwerty key board. It is dubious that the ezVue 6 is different having the same form factor.
Apr 10, 2011 | Royal EZVue 6
We have a Royal EZVue 6600HD printing calculator. We were using it today and the paper stopped advancing. We took out the roll of tape and reinserted it according to the directions in the booklet. ...
The paper thickness may have something to do with it. Also If there is grit or other debris on the pressure roller, that can hinder the advancement too.
If there is debris (sometime you can not see the residue) remove the current roll, get stout paper towel or rag, and using isopropol alcohol, clean the pressure roller. Allow 5 minutes to completely dry, and try again.
good luck and don't forget to vote.
Oct 12, 2010 | Royal EZVue 6
I have a Royal ezVue 7 PDA and I can't get the sync software to work. The computer reads and installs the software from the CD, and the desktop software appears to work, but to sync the desktop to the PDA...
Royal Extreme 7 will not sync properly.
It gets to Deleteing records and locks up.
Both the software and the PDA is then locked into the sync mode.
I have installed newer drivers as instructed by Tech support.
(MwNTXP.inf & rylm100.sys Files)
These files are listed under PDO Desktop>Drivers>WinNY2KXP.
I am using Windows XP Media Center Edition.
I have version 1.5 of the PDO Desktop program.
Is there a later version that works.
Frank Mattox
Sep 01, 2010 | Royal ezVue 7
24 people viewed this question
k24674
jasbo
jasbo
