Question about Suzuki 25Note Chromatic Tone Chime Set
What is the size of the hex wrench for B5 Suzuki chime screws?
The B5 head keeps coming off. I do NOT a small enough allen wrench to tighten the two screws. What is the correct size?
My ibanez sr700 bass guitar's volume knob is very
To remove the knob, there should be a small hex key or allen screw on the side of the knob. Just loosen the screw. You don't have to remove it.
To tighten the nut properly, you may have to remove the back panel of the bass and hold the potentiometer from the other side. If allowed to turn too much, it could mess up the wiring.
Feb 26, 2013 | Music
The wrench to adjust the Fender Jazzbass (Mexico) neck does not seem to be allen
it doesn't I think it is stripped if you have tried metric and S.A.E wrenches and nothing works this could be the case and it has stripped but try to look into the opening at the top of the nut with a flashlight if you can see the flats for an allen wrench then it might be still good but a weird size like 4.5mm ex. are you the original owner if not you could have a problem here but you might be able to get the nut out and put a new one in post back I want to check for the wrench size
Mar 27, 2012 | Fender& Standard J Bass Artic
How to change strings on vendetta
the strings on most floyd rose tremelo systems require a small allen wrench(hex head) to loosen the pressure on the bolts holding the **** end of the string in. should be easy access from the top of the guitar. hold the guitar up to your face, **** end first and look up the body towards the neck. there should be six different screw ends visible. loosen counter clockwise. you have to trim the ball end off of a new set with wire cutters in order to replace.
Feb 20, 2012 | Dean Guitars Dean Vendetta 1.0 Electric...
Some of my tone chimes feel like they are gummed up or something. The clapper head does not move freely. Any suggestions?
There are 2 hex head screws at the base of the plastic piece that holds the clapper. Unscrew them a little, and it should loosen up the head.
Sep 27, 2011 | Suzuki 25Note Chromatic Tone Chime Set
Need size of truss rod wrench. i need a manual
Takes a standard 'Allen Key' hexagonal wrench (I'm not sure of the size for your specific guitar but most are around 5 or 6mm)
Basic Epiphone manual here
http://www.epiphone.com/images/EpiOwnrsManul.pdf
Feb 17, 2011 | Epiphone AJ220SCE AcousticElectric Guitar
How to lower the action on a b.c.rich warlock bronze series
To fix the action on your B.C.Rich Warlock, you need an Allen Wrench, or Hex key. There is a truss rod cover on your B.C.Rich's headstock. Just open it using a screwdriver and you will find the truss rod. Then adjust the action using the hex key.
check out more here -
http://www.squidoo.com/b-c-rich-warlock-set-up-and-fixing
Nov 20, 2010 | B.C. Rich Dark Arts Warlock Electric...
The clapper on the A#/Bb-6 and C-7 chimes are broken. The clapper head is completely gone. Where can I get a replacement part and how is it installed. I have been searching the Internet for days to no...
Frankly, I would analyze what the clappers ar made of and MAKE them yourself. If they are plastic, find suitable material and make your own. If metal, you can have a metalshop make some for you.
Finding replacements either piecemeal or individual chimes is NOT likely to happen.
Aug 09, 2010 | Suzuki 25Note Chromatic Tone Chime Set
How to adjust the neck on a fender jazz bass
depending on the model you will see a place for an allen wrench. it will be either on the end of the neck half way under the body, or most likely at the headstock just under the fret board. Find the correct size allen wrench and turn it about a 1/4 turn at a time. im not sure why your looking to adjust your neck so i cant really say what to look for.
Apr 18, 2010 | Fender& Standard J Bass Artic
I have a Fender Squier Strat. The Whammy bar is
There are MANY tricks to remove a threaded piece like this:
1. With a Dremel tool and a cutoff carborumdum disc cut a shallow slot in the remaining piece and use a straight bladed screw driver to remove. This can only be done if the screw is above or flush with the surface.
2. Carefully drill a small hole in the piece fairly well centered. Use an "EasyOut" to remove the broken part.
3. Carefully drill several small shallow holes on the top of the broken part in a line so as to form a slot for a screwdriver.
4. Carefully drill a hole JUST the right size into the broken part and then drive an Allen wrench into the hole to turn the broken part. The hole has to be just the right size so the wrench can peal tiny pieces off to grab the broken part.. this is tricky to get the size just right.
5. Use a detist drill to cut a slot.
In all these use a penetrating oil or CRC226 to make it easier to turn.
Mar 08, 2010 | Fender Squier Std Strat Mn Car
Schecter Diamond Deluxe Stilleto Bass-How to Lower Strings
I hope you dident screw it up, a person can realy mess up the platability in a hurry if you dont know what your doing. Lets see if we can get you on a good track .What your looking at is your tali pice. that whitch holds 6 saddels the saddels have horizontal screws. Hex you need a very little alan wrench. they normaly come with a new Ax.string heights are 2.00 at the 5.th and 1.5 on the 1first. use a line of sight to see that strings are in a good line. Never Never screw the vertacal screws with springs. Thisis your intonation. if you mess this up you lose the playabilithy of you gtr. ps Guitars dont come with manuals. check with your local music stoer. find a musician thats will ing to give some hands on tips.
Apr 10, 2009 | Schecter Stiletto Deluxe-4 Bass
Suzuki 25Note Chromatic Tone Chime Set Logo
Top Suzuki Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Suzuki Music Expert? Answer questions, earn points and help others
