Question about Stihl Br 500 550 600 Backpack Blower Throttle Cable Assembly 42821801100
Model BR420. How do I install throttle cable?
  • Stihl Master
  • 1,807 Answers
Broke a throttle cable - can't see how to re-attach the new cable to the twist grip.
You have not listed your model.
Generally, remove two or three screws holding the right hand control module together. Remove old cable, install new cable in housing, and cable end in throttle tube. Reassemble.
Oct 06, 2015 | 1995 kawasaki KLE 500
How to install a new throttle cable on a 20" 300 series weedeater lawnmower
...ummm, there isn't a throttle cable on that model, do you mean the engine shut-off cable?
Jul 18, 2014 | Garden
How to install a throttle cable model 3120xp
Instructions
1 Push the end of the new throttle cable onto the linkage on the carburetor, this is held in place with a clip, but on some other vehicles, the end of the throttle cable is capped and simply slides through a slot on the linkage.
2 Place the throttle cable clip over the linkage. You may need to pry the end up with a flat-head screwdriver to get it in place.
3 Secure the throttle cable in the throttle cable bracket located on the intake manifold. This, too, should clip into place.
4 Route the cable into the cab, being sure to keep it kink-free.
5 Loop the end onto the end of the accelerator pedal inside of the linkage hole. In other vehicles, there may be a clip on the accelerator pedal that holds the throttle cable in place, which is also easy to do with your bare hands.
Jun 24, 2014 | Husqvarna Garden
Throttle cable replacing
What year model. Take tank off. Take cover off throttle on handle bars. Release tension on throttle cable by loosening cable adjusters. Release cable from carburetor. Release cable from throttle housing on handle bar. Reverse instruction to install new cables ...2 cables.
Sep 29, 2013 | Harley Davidson FLHTCUI Electra Glide...
1994 Kawasaki ZZR 1100 throttle cable installation
Hi, Allblacks71 for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Throttle cable installation 2007 Kawasaki ZZR600 or ZX600J How To Presented By BikeBandit com Install Throttle Cable
Kawasaki Ninja ZX 11 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Mar 04, 2013 | 1994 kawasaki ZZR 1100
I NEED A MANUAL FOR A STIHL BR420 LEAF BLOWER
You can find an instruction manual for your model here. Visit PartsBuggy.com for replacement parts.
Oct 11, 2011 | Garden
Replace throttle cable
There are two cables leading to the throttle. Both have two pieces.
Cable 1 goes from the throttle about 12" long and connects to an adjustment piece joining it to cable2 which goes to the throttle body.
Cable 3 also goes from the throttle and is about 12" long and connects to and adjustment piece joining it to cable 4 which goes to the spring on the throttle body.
To change any of them you must loosen the adjustment piece until the ends can be removed from it.
Then to change cables 1 and 3 you have to remove the throttle cover on the grip. you will be able to see how they are removed. Then reverse these steps to install the new cable.
To change cables 2 and 4 in no more difficult but more time consuming as you will have to route these longer cables from the adjuster to where they connect to the throttle body.
When cables have been install and all parts reassembled you can carefully adjust the tension on the cables until the throttle responds the way you like it.
Hope this helps
Sep 19, 2011 | Harley Davidson XLH Sportster 883 Hugger...
Where is throttle positioning sensor on a suzuki forenza
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disconnect the Intake Air Temperature (IAT) sensor connector.
  3. Disconnect the breather hose from the valve cover.
  4. Remove the air intake tube.
  5. Disconnect the throttle cables by opening the throttle and moving the cable through the release slot.
  6. Disconnect the vacuum hoses from the throttle body.
  7. Disconnect the Throttle Position (TP) sensor and the idle air control valve connectors.
  8. Disconnect the coolant hoses from the throttle body.
  9. Remove the throttle body and discard the gasket.
  10. Remove the TP sensor.
  11. Remove the Idle Air Control (IAC) valve.
  12. Remove the throttle body retaining nuts.
  13. Remove the throttle body.
To install:
  1. Install the throttle body.
  2. Connect the TP sensor connector and the IAC valve connector.
  3. Connect the coolant hoses to the throttle body.
  4. Connect the vacuum hoses to the throttle body.
  5. Connect the throttle cable.
  6. Install the air intake tube.
  7. Connect the breather hose to the valve cover.
  8. Connect the IAT sensor connector.
  9. Connect the negative battery cable.
  10. Fill the cooling system
  12. i hope this helps tps is attatched to hrottle body on other side than throttle cable
  13. plz dont forget to vote rep[ly if you need more help
Jan 17, 2011 | 2006 Suzuki Forenza
When i turn on heater or fan engine revs over 3000 rpm
Idle Air Control Valve Pintle may be bad If you disconnect the IAC and the problem ceases it can point to this being the problem.: Removal & Installation 3.5L Engine To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the fuel injector sight shield.
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • The air cleaner intake duct. Figure of IAC and TPS electrical connectors disconnected. aurora_g1.gif
    • The idle air control (IAC) valve and throttle position (TP) sensor electrical connectors. Figure of cruise control and throttle control cables removed from throttle lever. aurora_g2.gif
    • The cruise control cable and throttle control cable from the throttle body lever.
    • The fuel pressure regulator vacuum hose, positive crankcase ventilation (PCV) hose and the throttle body vacuum port hose.
    • The throttle body coolant hoses.
    • The throttle control cable bracket, leaving the throttle and cruise cables connected.
    • The upper nut holding the throttle body to the intake manifold.
    • The throttle body assembly.
  5. Clean the gasket mating surfaces.
To Install:
  1. Install a new gasket and new studs if necessary.
  2. Install or connect the following:
    • Start the top nut by hand.
    • Position the throttle control cable bracket and hand start the retaining nuts and bolt.
    • Torque the three throttle body retaining nuts to 89 in.lbs. (10 Nm). And the bracket retaining bolt to 115 in.lbs. (13 Nm).
    • The throttle body vacuum port hose, PCV valve hose and the fuel pressure regulator hose.
    • The throttle control and cruise control cables to the throttle body lever.
    • The IAC valve and TP sensor electrical connectors.
    • The air intake duct.
  3. Refill the cooling system.
  4. Install the fuel injector sight shield.
4.0L Engine To Remove:
  2. Relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable.
    • The Mass Air Flow (MAF) sensor electrical connector.
    • The PCV valve fresh air tube. Figure of cruise control cable removed from throttle cable bracket. aurora_g3.gif
    • The cruise control cable and throttle control cable from the bracket.
    • The cruise control cable and throttle control cable from throttle body lever. Figure of IAC valve and TPS connectors removed. aurora_g4.gif
    • The idle air control (IAC) valve and throttle position (TP) sensor electrical connectors. Figure of fuel lines removed from retainer on throttle cable bracket. aurora_g5.gif
    • The fuel feed and return lines from the retainer on the throttle control cable bracket.
    • The transaxle shift cable clip from the throttle control cable bracket. Figure of throttle body removed from water crossover. aurora_g6.gif
    • The throttle body from the water crossover.
To Install:
NOTE: The Mass Air Flow (MAF) sensor inlet and the outlet of the air cleaner assembly must line up when installed. Misalignment may cause MIL illumination or driveability concerns.
  1. Install or connect the following.
    • The throttle body to the water crossover. Torque the bolts to 106 in.lbs. (12 Nm).
    • The throttle and cruise control cables to the throttle body lever.
    • The throttle and cruise control cables to the throttle control cable bracket. The transaxle shift cable clip to the throttle control cable bracket.
    • The fuel feed and return line retainer to the throttle control cable bracket.
    • The MAF sensor electrical connector.
    • The air cleaner intake duct clamp. Torque the clamp to 27 in.lbs. (3Nm).
    • The fuel injector sight shield. Torque the nuts to 20 in.lbs. (2.3 Nm).
  2. Install the negative battery cable.
  3. Pressurize the fuel system and verify no leaks.
Oct 07, 2010 | 2001 Oldsmobile Alero
Stilh leaf blower and it surges
How old is it?
Your brief description of the problem points toward air in the fuel lines.
Remove the engine cover, and try to see how flexible the fuel lines are. If they are hard and brittle, it's time to change them.
If you need further assistance let me know.
Apr 19, 2009 | Garden
Stihl Br 500 550 600 Backpack Blower Throttle Cable Assembly 42821801100 Logo
557 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
