Question about Tappan TEF242 Electric Kitchen Range
Over heating set to 350 or 400 or 450 and oven shows heating to over 600 on thermometer
    Top Expert:
  • Tappan Master
  • 9,472 Answers
You will need to replace the oven thermostat. Here is the part to order.
Posted on Dec 10, 2012
  • Parmelia Schmidt
    Parmelia Schmidt Dec 10, 2012
    Took the back off to get to the thermostat and found my problem.....a mouse had crawled across the thermostat and one of the 'hot' leads. Removed the mouse and oven is working fine again. Thanks.
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
Thermostat broken?
If your oven has a dial that is used to set the temperature instead of a digital control then yes, the thermostat has gone bad and is not shutting the heat off at the appropriate time.
May 17, 2012 | Smeg S20XMF.1 Stainless Steel Electric...
The oven does not heat to the set temperature. It is usually much hotter
You can have the oven recalibrated by a professional OR you can purchase an oven thermometer and check the temperature yourself. Place the oven thermometer in the oven.Set the oven to a specific temperature. When it indicates it is at that temperature check the thermometer. Adjust your setting by that many degrees. For instance, if you set the temp at 350 and the oven thermometer shows 450, then reduce your temperature setting by 100 degrees each time you use the oven.
Nov 15, 2010 | Amana RanARG7302 Gas Kitchen Range
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
I have a Competence 52081 double oven. Ity has
Thermostat may need adjusting OR air may be entering the oven causing the problem
Sep 01, 2009 | Ovens
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Oven heat erratic
no there is not and your unit only has one temp sensor you will have to spring for a new control
Jan 07, 2009 | Ovens
Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Oct 17, 2007 | KitchenAid KESC307 Electric Kitchen Range
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan TEF242 Electric Kitchen Range Logo
125 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
