Question about HP LaserJet Pro 400 M401DN Laser Printer
M401dn won't print pdf's correctly
Prints word docs correctly but pdfs print as if they are scaled to print smaller. I have reset to factory default on both printer and computer. I am using the pcl6 driver with XP.
  • 163 Answers
SOURCE: HP Laserjet 1320 - Acrobat problem in XP
please reinstall the printer driver and also reinstall your window
Posted on Sep 19, 2007
no_pc-gst
  • 58 Answers
SOURCE: Laserjet 1022n and Universal Print Driver
i solved this problem in my case with an compatilble standard driver from windows. An PCL Laserjet 5 / Laserjet 6 Driver.
And no problems occour.
On the clients and the server all iss fine.
Posted on Dec 31, 2008
SOURCE: hp laserjet 3600 PCL XL error when printing a PDF
This is a known issue with 'host-based' printers like the 3600. You need the PCL5 driver, which this printer will not work with. You need a different printer, such as the HP 3520.
This page will explain it all.
Posted on Oct 07, 2009
  • 127 Answers
SOURCE: My HP deskjet 2050 all-in-one
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
Posted on May 31, 2011
SOURCE: My HP Officejet 6500 Wireless
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
Posted on Jun 20, 2011
When I print a doc it prints in blue. If I run a test page it prints black and blue no other colors. I reset the defaults on the menu but it printed one doc in black then started in blue again.
Uninstall then reinstall make sure you have the correct install for your operating system.
go to the manufacturer and look under support for your printer
Feb 03, 2011 | Computers & Internet
Page isnt prining out Have new ink in printer
Before you can troubleshoot the problem, determine its cause. Do the following steps in order:
1. Print another PDF, such as the first page of Acrobat Help.
  • If a separate PDF file prints correctly, the PDF that doesn't print correctly could be damaged. See "Can't print a specific PDF file" later in this document.
  • If the separate file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a plain text file) from another application (such as Microsoft Word or WordPad).
  • If that other type of file prints correctly, the problem isn't system-wide--it's specific to the Adobe Reader or Acrobat product. However, the problem could come from Reader or Acrobat interacts with the system. Go to step 3 to eliminate some system-related causes of the problem.
  • If that other type of file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDFs. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF.
  • If the file prints correctly, your system may have been out of memory or resources.
  • If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory. Then turn it back on and print a PDF.
  • If the file prints correctly, the printer's memory was too full or had become corrupt.
  • If the file still doesn't print correctly, go to step 5.
5. Print from another computer.
  • If the file prints correctly from another computer, the computer you first used may be unable to connect to the printer or the network correctly. Consult your network documentation or contact your network administrator.
  • If the file still doesn't print correctly, go to step 6.
6. Print a PDF to another printer.
  • If the file prints correctly to a different printer, the computer you first used may be unable to connect to the original printer. Communication, hardware, or memory problems can cause this kind of connection problem. Make sure that the printer is turned on and connected properly. Then run a self-test on the printer to make sure that it's working correctly. Consult your printer documentation for self-test instructions or contact your network administrator.
  • If the file doesn't print correctly, see "Can't print any file from any application" later in this document.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Lexmark Z611 InkJet Photo Printer
Pdfs not printing all of the text
Several issues may be responsible for this, one you may not have right to print or copy, please check from the file menu the document properties, check security.
The other is check the printer properties, click on fit page
Mar 10, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Printed text is very small, not legible and does
Go to to print menu box i.e. press ctrl P. Look for zoom. There you will see "scale to paper size." Here select from the drop down list "no scaling" or "A4" depending your paper size. This shoule correct it.
In case you do not see these on your print menu click "properties" on your printer. In the box that appears look for "scale" and make it 100%. These are the components that control percentage size of original documents printed.
Dec 08, 2009 | HP DeskJet 930c InkJet Printer
Prints gibberish
You need to ensure you have the correct drivers for your computer. Adobe uses PostScript drivers to print out .pdf files. Some drivers are Printer Control Language (PCL) and do not work well with .pdf.
Dec 25, 2008 | Brother HL 2700CN Laser Printer
Pdf printing
you need to check for any 3rd party xtension that would support the baove mentioned feature. you can try to search the same on google or can call their tech support to check if they have any information on the same
Apr 02, 2008 | Adobe Acrobat 7.0 for PC
PRINT SCALING
Print scaling adjustments are in the print driver.
They are in different locations depending on the driver. PCL or PS.
But there will be a scaling adjustment within the driver in te properties.
Will have to search through the driver features to find it.
Jan 14, 2008 | Xerox Phaser 7400/DXF Laser Printer
Canon C3220 PDF print problems
http://www.adobeforums.com/webx?14@@.3bca0e93/7
Nov 12, 2007 | Canon imageRUNNER C3220 Printer
HP LaserJet Pro 400 M401DN Laser Printer Logo
460 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
