Question about Sharp Mx-2310u Color Copy/print/scan
Printer not printing, que says printing - Sharp Mx-2310u Color Copy/print/scan
I can't print the items in my printer queue. How do I get them to print?
It sounds like you have a print job stuck in the print que. When this happens the print jobs after the stuck one will not print either. You will need to clear the print que and reprint the jobs. Here is a link to an article showing how to purge the print que and get your printer back printing again.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Apr 14, 2013 | Lexmark X7350 All-In-One InkJet Printer
Deleting Printing Queue
you must give clear all in log settings....
Feb 17, 2008 | Canon imageRUNNER C3220 Color Copier
Print que on hp 4300 says "printing" but nothing happens and I cannot clear que
This is a common problem with Windows machines. If a print job gets corrupted in the print que it will stop and block all other jobs from printing. It will also block the job from being deleted normally. You have to stop the print que service and then delete the print jobs from the que. Here is a link to a full article that shows how to stop the que, delete the print jobs and restart the que to restore printing.
Nov 29, 2012 | HP LaserJet 4300 Printer
I want to clear the que. I tried to print a page and it will not print. It has remained in que for two days. I have tried to cancel it, didnt work. I unplugged the printer and usb cable, it still did...
If you are using windows operating system than go to Printer and Faxes, Double click on the printer icon. A window with printing document que will appear, click on "Printer" and select "cancel all documents" and then switch off the printer for few minutes. the document que will disappear.
Aug 12, 2011 | Lexmark X5650 All-in-One InkJet Printer
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Job in printer que will not print or delete
go to safe mode and then delete the queue in printer
May 18, 2010 | HP Deskjet 6940 InkJet Printer
I have Dell 1600n and run Windows Vista 32-bit. Whenever I print, I have to manually clear the print que. How do I have the print que automatically cleared after every print?
Go to the printer properties and untick print que and select print directly t o printer option.Alternatively download the rpcs drivers instead.
Jun 25, 2009 | Dell 1600n All-In-One Laser Printer
Items in print que
go to start/control panel/printers&faxes
you will see what is in the que
the print jobs will stay in the que until you shut off the printer
if you have shut off the printer, the que will be emptied and not retrievable
May 05, 2009 | Lexmark Z640 InkJet Printer
Printer not printing documents in que
my printer hp psc1315xi all in one printer copier, scanner will not print any documents, not even a test print, there is also a doucument in it that am not able to delet from the printer
Jan 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
My printer isn't printing
ok i suppose it printed before and i suppose you have the ink and paper in it ok the printer is in standby mode in the print que soclick the print que button on the tray start printing click start printing in the taskbar and never pusg print 2 0r3 times or more then pages in you que become ready to print if not start printing in the print ques turn off the printer unplug it wait for 30 seconds restart pc then the print que is empty
Apr 04, 2008 | HP PSC 1315 All-In-One InkJet Printer
Sharp Mx-2310u Color Copy/print/scan Logo
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
