Not optimum mode recommended mode 1600x900 60 Hz
Hi swapnil sharma my problum not optimum mode recommended 1600*900 mode60hz
Posted on Mar 21, 2013
  • 7,627 Answers
Your Graphics is out of range.
Posted on Dec 10, 2012
4 Suggested Answers
SOURCE: Screen is black, white square
Your resolution has been to a "not supported" range. You can try to boot to safe mode by pressing F8 while booting. While in safe mode, go to device manager and look for your video adapter there. Delete the driver for it and reboot the computer.
That should reset it for you.
Hope this works for you.
Posted on Aug 22, 2011
kenshin99
  • 89 Answers
SOURCE: my monitor has a message
You will have to change the resolution of your screen as well as the refresh rate. Go to the Display settings of your computer and set the resolution to 1280x1024 and refresh rate to 60Hz.
Assuming you are using windows vista:
Right click on your desktop and select Properties > select Display settings > change the resolution to 1280X1024. Go to Advance button > Monitor tab and set the rate to 60Hz. Click Apply then OK.
Good luck and have a nice day!
Posted on Sep 30, 2008
  • 36 Answers
SOURCE: Samsung Syncmaster 710n monitor -
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Posted on Oct 27, 2009
I have samsung syncmaster sa300 20 led monitor, How to fix Not Optimum Mode Recommended Mode 1600 x 900 60 Hz analog, can not playing games
hi
im from iran
i have a monitor samsung sa300 18.5" that one of ics burn and i cant read his number its 8 pin and is up of the data port input. two crakter that begin by it , is at **22
please help me
Feb 09, 2012 | Computers & Internet
Screen is black, white square is moving around says "Not optimum mode Recommended mode : 1280x1024 60 Hz' Analog"
Aug 22, 2011 | Computers & Internet
Not optimum mode Recommended mode:1280X1024 60 Hz
u can change logic board r update bios using with ddc manager
Jan 18, 2011 | Samsung SyncMaster 713BM 17" LCD Monitor
I have a Samsung SyncMaster 901B, it's not new, a friend gave it too me, i connected it to my computer,i start the computer, it works fine until windows finishes loading, then the screen goes black and i...
What happen when you hook this monitor up to other PC that has the video setting 1280 X 1024 60 Hz? Just ant to narrow down the problem before opening up the monitor. You may have logic problem in the logic board. If it does the same with other PC, then open it up and inpsect the inside for such thing as failed caps on the logic board or on the main power supply board, I think more likely to be ROM chip on the logic board is scrambled.
See typical failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | Computers & Internet
How do I change the setting on my Syncmaster monitor if I can't see anything but the message box..."Not Optimum Mode recommended mode 1280x1024 60 hz?
You could try pressing the auto adjust button (simply says 'Auto'), and see if that changes anything...don't know if this will work, but it is a start.
Sep 29, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Monitor stops working and box start floating around on screen with "Not Optimum Mode -- Recommended Mode 1280 X 1024 60 Hz." Replacement monitor works on computer.
check if your monitor has an auto-adjust button, this will help you autoadjusting the recommended resolution so that there are no problems, if not, you can try to rightclick on windows desktop and go to properties>configuration, set the resolution there
Sep 16, 2009 | Computers & Internet
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Monitor goes black
Does it show a picture in safe mode? If it does you might want to install drivers specific to the Monitor if you can find them.
Jun 18, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Computers & Internet Logo
2,571 people viewed this question
David Payne
David Payne
