Question about Toro Garden
I have a Toro Z420, when put in park it still creeps forward. Is there an adjustment that I can make to stop this?
2 Suggested Answers
  • 27 Answers
SOURCE: Hey! I thought you was gona send the wiring diagram for that toro z420
It's in the mail. Should get there in another week or two.
Posted on Aug 12, 2014
How much and what do I put in gearbox of my Toro z420 mower
these are sealed transmissions. unless your rebuilding it, don't change the oil.
Oct 15, 2015 | Toro Garden
Is there a place to check the hydraulic fluid on a 2005 toro Z420
sounds like your hydraulic motor maybe acting up. you need to check your hydraulic oil flow rate. if you don't have the tools you would have to take it in it is a fairly big job
Oct 07, 2014 | Toro Power Lawn Mower
Toro z420
you have to adjust your tracking. Your manual tells you how to do this
Jul 23, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Need free online manual for Toro Timecutter Z420 + 74327
Jump onto the Toro website - www.toro.com, ALL the manuals are available there for FREE :)
Sep 16, 2013 | Toro Garden
We recently bought a second hand Toro Z420 ride on mower but there wasn't any manuals with it can you help as I can't seem to print one from your site even though you say we can?
hi there pauly 46 here
hi peg ed
here is web site to download service manual
http://www.kohlerplus.com/main_frame.asp
enter as guest
select kohler courage single, then scroll down to service manual , then select SM 20-690-01
(replaces tp-2548 a) and download a copy to your hard drive its 6.05 Mb
here is web site for toro manual
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#productDetailsPage
under manuals , enter 74327 as model , time cutter z420 will come up in a list of 2
see if this will let you print anything
cheers
May 16, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Tororider1338hxl how do I adjust the forward and reverse pedal it goes forward but not backwards verywell
Adjustment for this machine is made with the machine in the air. There is a cam nut on the right side of the transmission that can be adjusted to give more forward or reverse. Do this while in the air to make sure the machine does not creep away during adjustment.
see a local dealer like www.arcolawn.com for more tips and parts.
Mar 19, 2011 | Toro Lawn Mower With Toro Power Tools
Hi my days strider midi4 keeps going in reverse for about 4 seconds after you take the throttle off
spares sounds like the throttle pot is not being centered upon release making the scooter move in reverse or forward depending on which way it is off center. try pushing on the thottle lever slowly forward when you stop to see if that stops the creeping. Then you can try to adjust the pot by loosening the lever and retightening it in the forward direction that stops the creeping. You might have to order a new throttle pot assembly to get this working right. Hope this helps
Nov 18, 2010 | Electric Strider Midi 4 Wheel Mobility...
Engine running--when i engage parking brake it creeps forward how do I adjust
your brake pads are probably spent or you need to adjust them....usualy behind the rear passanger tire...lol
turn the nut clockwise justa half turn...put the tire on and try again...this prosses is very painstaking because most of these machines its hard getting to this nut with the tire on
Jul 19, 2009 | Garden
1997 ford explorer rolls/creeps forward while in park
linkage is off, not starting in park, neutral safety switch maybe bad
Nov 26, 2008 | 1997 Ford Explorer AWD
Garden Logo
54 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
