Question about Williams 3003622 Ceramic Wall Mounted Panel Heater
Condensation freezing. I live in Kenai, Alaska and installed a 300622 in my garage a couple years ago. In the winter when it gets coldest the more the heater runs the more ice I get going up the wall from the exhaust. I keep the temp at about 55 to 58 degrees. Do I need to extend the exhaust above the roof and does this effect the air intake? What kind of stack do I need to use for it and how will it effect the heater itself? I have pics to send it needed. Thanks j. gregson
  • 2,976 Answers
Lust extending the exhaust outward a foot should help with the ice on the wall problem. A regular metal stovepipe should be all you'll need.
Posted on Jan 30, 2009
Where does a bald eagle live?????????????????????
Bald Eagle National Wildlife Federation
Their range extends from the Mexico border through the United States and Canada. Bald eagles are extremely populous in Alaska! If you live in Alaska, along the East and West coasts, the Rocky Mountains and the Mississippi River then you can see bald eagles all year. The rest of the United States only sees bald eagles during the winter and their migration.
Aug 20, 2017 | Miscellaneous
I want to replace the original carb on my 75 MGB with a weber, should I use a water, manual or electric choke weber carb ??
It depends on where you live really. Let's say you live in Texas, the fall and winter mornings can be bitterly chilly...but by noon be hot as heck. During the summer it is hot always. If it were me I'd use a manual choke in southern areas. or if I were in Michigan I'd probably use a electric choke. I actually say that because manual chokes in a place like Michigan will get stiff, rusty or freeze without proper maintenance and shielding. I lived in Alaska and Cheyenne Wyoming and noticed in Alaska that cable chokes and linkages would bind up in extreme temperatures. But when all else fails try the Weber Electric choke.
Jan 30, 2017 | MG Cars & Trucks
How to install engnie freeze plug 90 toyota celica st
Hi, are you talking about anti freeze, if so it goes in the engine coolant in the radiator, check the manufacturers specifications for the correct ratio of anti freeze to water for your climate, which I assume changes from season to season. In winter you may have to use 100% anti freeze for the coldest times of the year.
Dec 20, 2012 | Cars & Trucks
What kind of coolant do i use for a 2004 Kia Ria, 50/50 OR 35/65? I live in Alaska. Need an answer asap.
when you live in really cold climates it is important to run more antifreeze so the water does not freeze and blow out a freeze plug. i live in california where its always warm so i run a 50/50. i would imagine alaska gets pretty cold so i would probably run more antifreeze
Sep 15, 2011 | 2004 Kia Rio
Leaving a fridge in a cold garage
a fridge will not work right in an un heated garage
Dec 17, 2009 | Refrigerators
Motor is locked up. mercury mariner 125.
I take it you didn't winterize the engine? If that's the case what usually happens is a light film of rust has bloomed in your cylinders over the winter due to condensation and the starter can't overcome the friction. I had this problem a couple of years ago. The guys in the shop had me buy a can of fogging oil, remove the sparkplugs and squirt it into the holes until it backed up twice a day for 2 days. Then leave it alone for 72 hours with the plugs in. That was it! it actually worked for me! Hope it helps you to....
May 10, 2009 | 2002 Mercury Mariner
Freezer doesn't freeze in winter?
Domestic refrigerators nowadays are designed not to operate at temperatures less than 45 degrees. First, if it's 45 degrees in the house, people probably are not living there. 2nd, 45 degrees keeps food refrigerated. 3, if people are not living in a space, then they don't need to keep frozen food.
This is a result of the changes in refrigerants we've been going through since 1992.
If you want an outdoor freezer, buy one, and make sure it's designed to be used in a non conditioned space.
Jan 26, 2009 | Frigidaire FRS23KF7AB Side by Side...
Williams 3003622 Ceramic Wall Mounted Panel Heater Logo
62 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
