Question about Mitsubishi WS-73909 73" Rear Projection Television
MITSUBISHI WS-73909 will not turn on 1. I have a Mitsubishi Big screen TV model no WS-73909. Few days a go the city power went out when the TV was off. The TV had a surge protector. Then the TV will not go on and a small green light labeled ?timer? was blinking continually. 2. After about 3 days the light went off and the TV will go on. I turned it on and off and it worked fine. Then I disconnected it from the electricity to install a better surge protector between the TV and the wall. Now the TV will not turn on again and it has the same symptoms as described in item number 1 above. Did any one run into this before and knows the remedy?
  • pizzed off Mar 06, 2009
    I have the MITSUBISHI WS-73909 5k for it a few years back this is my 5th I had 4 small 65" and there was something wrong with everyone of them but they wouldn't give me my money back , yad yada yada NE way noy I get to watch a lil green light flash in HD I can't even get it to bring up a code I'm gona replace the 7 cap's tommarow but they don't look bad. will let you'z know.....
    Champion:
  • 240 Answers
It is normal for the green light to flash for 70 sesonds at first plugin the set will not turn on while it is taking place try it again after the light stops blinking.
now if your still having problems I need the error code
to get the error code Hold down input (device) and menue at the same time for 5 sec.
the led will start blinking an error code to you.
if it is broken we need the code.
thanks.
daniel
Posted on Jan 13, 2009
    Sergeant:
  • 233 Answers
I have your fix... email me - doin12volt at yahoo- and please, once you review this fix, remember to rate this answer!
I have a Mitsubishi rear projection TV (WS-73909) that didn't turn on and had a green blinking light. I replaced the 7 DM capacitors and now it turns on. Both the remote and front control panel ca
Let me know as I can look for this---the set has a keyboard lockout that is cleared by holding the menu or another front button for more than 5-10 seconds with set on---I can find the service manual and check if needed.
Nov 04, 2012 | Mitsubishi WS-73909 73" Rear Projection...
MITSUBISHI WS-73909 will not turn on 1. I have a Mitsubishi Big screen TV model no WS-73909. Few days a go the city power went out when the TV was off. The TV had a surge protector. Then the TV will not go...
Are you a Quailified Technician ? Because this repair is not for the novice. The best thing I can tell you is contact a Mitsubishi Authorized repair center or tell me what area you live in and I can find one for you. cost is 250-350 to repair.
Apr 10, 2009 | Mitsubishi WD-65000 65" Rear Projection...
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi ws65869 big screen tv
Does the LED power light come on? Have you checked the fuses?
Feb 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Big Screen TV not working
Check your video input cable or replace, maybe it is damage if not Video chip problem etc
Dec 16, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Open Questions:
Mitsubishi WS-73909 73" Rear Projection Television Logo
659 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
