Typewriter cylinder barrel does not move in either direction
I must have flipped a lever and locked the cylinder barrel because does move, I have tried advances it with the space bar as well as sliding it over, but it remains locked Can anybody help me?
  • 3,594 Answers
You didn't give a make or model but usually there is a lever just below the carriage on thbe R or L side that unlocks them.
DickyO
Posted on Dec 12, 2012
SOURCE: carriage release
try jiggling the carraige around a bit and then try using that lever thats on the right side of the carraige. you might even try both at once to see what frees it up. i had the same problem and it worked for me. That's the right tab, it may be in a jammed position so it wont open properly.
Posted on Jun 13, 2007
  • 117 Answers
SOURCE: Cant move carriage lock
it should slide from front to rear.Maybe it could use a drop of oil.I use Marvel mystery oil
Posted on Mar 24, 2009
  • 117 Answers
SOURCE: Cant move carriage lock lever
Try lubricating the lock lever with a drop of Marvel Mystery oil.It should slide from front to rear
komguy
  • 2306 Answers
SOURCE: Wheelwriter 6 typewriter hammer no longer strikes
It is pretty common for the pad on the solenoid to strike the keys wears out, and for the batteries to be dead for the memory. Your machine probably needs a good cleaning, oiling, and a new pad for the striker. about $100.00 in the shop.
Posted on Jun 30, 2009
  • 14 Answers
SOURCE: Manual Typewriter Carriage Movement Problem
Without knowing the make it's hard, but it could be that some of the roller bearings used to make the carriage run smoothly have come out of the retainers and dropped from the machine. If as you say there is a lot of slop in the inner carriage it's a fair bet that's your problem
Posted on Oct 19, 2009
The roller already locked at centre position and cannot moved to left or right, how can I release it?
the return lever will allow you to move it to the right
on each end of the roller there are small levers that when pressed allow the roller to moved in either direction
Sep 11, 2015 | Office Equipment & Supplies
Cannot unlock the carriage
There is a little lever under the carriage on the left,used for locking the carriage when in transit.Move the lever in the opposite direction,if that does not work press the Capital Lock Key then try it.If this does not work,it will be your carriage return spring having lost its tension.This is the round drum(wheel ) on the back of the carriage connected by a cord.
Oct 29, 2011 | Olivetti Lettera 25 Typewriter
Olivetti Lettera 32 typwritter carriage doesn't move
If the locking lever is off, then the carriage is bound, or one of the tabs is hung, try releasing all the tabs, pushing the space bar or the tab key while gently moving the carriage.
Try all of the function like shift while gently pushing on the carriage always to the right..
also check the that the margins are not locked.
This could be a lot of different things...
Dec 18, 2009 | Olivetti Lettera 35 L Typewriter
Can't find carriage lock on Olivetti Lettera 25
Learn how to unlock the carriage in Olivetti Lettera 22 Manual posted by Ed Cornish (Carriage Locking Lever 7). It is a different machine model, but the lock/unlock mechanism might be the same.
You can see the full manual at Ed’s Flickr account or you can download it from here: http://dl.getdropbox.com/u/1322442/Olivetti%20Lettera%2022%20Manual.pdf (temporary link)
Aug 28, 2009 | Olivetti Lettera 25 Typewriter
Barrel does not move along and only prints caps!
U HAVE NOT UNLOCKED THE CARRIAGE. LOOK AT THE VERY ENDS OF THE CARRIAGE AND U WILL FIND A LOCK THAT HAS TO BE REALEASED, OR THE LOCK COULD BE COMBINED WITH THE PAPER LINE SPACE SELECTOR.
Mar 25, 2009 | Office Equipment & Supplies
The cassette doesn't move !! it's just stuked to
Hi:
Sometimes small portable typewriters like that have a locking lever located on the side of the carrier. The carrier is the unit that has the printwheel in it. Look on the right side of the carrier and see if there is some type of locking lever that can be released.
Mar 07, 2009 | Brother GX-6750 Typewriter
Cant move carriage lock lever on the olivetti lettera typewriter.
Jan 01, 2009 | Olivetti Lettera 35 L Typewriter
Typewriter troubles
First,the paper problem is most likely that your paper release lever is in the forward position,just click it back and you will find that the paper will stay in place and space upwards when carriage return is pressed. Make sure that the printing unit can move freely to both extremes of its travel when the machine is turned off. Lift the top cover up and move the print unit by hand, it will feel stiff but it will move. If all this is in place your problems are over....
Nov 03, 2007 | Brother GX-6750 Typewriter
How do you unlock a locked carriage?
The solution is not right--there is a carriage return release lever on the far right of the typewriter, that engages a notch on the underside of the roller/carriage return--push it forward to release the lever and you are in business--it has a spoon shaped end and its on the right side
Jan 24, 2006 | Olivetti Lettera 35 L Typewriter
60 people viewed this question
k24674
jasbo
jasbo
