Need repair manual for Kodak Office Hero 6.1
Originally posted this in camera category. Power light comes on, and stays on, with application of power. No LED, print head is parked under laft side. Machine will not power up or turn completely off. Should not be in sleep mode. Was never on.
  • Robert Fletcher Dec 10, 2012
    Have removed 36 volt, external power supply, numerous times without a chnge. One time, machine was without power for three weeks. It then came on and appeared to operate normally for short time. Then failed again. During that period, print was terrible. In retrospect believe the problem is associated with the print head but being parked under the left corner, it is not acessible .
Mix-it-up
  • 832 Answers
SOURCE: Can't get color to print-black works fine.
You are on the right way. Press MENU then the blue START MONO Button which normally starts copies in black and white modus. After that press the round button (which can be normally pushed to four sides l/r up/down) UP four times. Now you should be in maintenance modus. Follow the procedure as mentioned before. If there are more questions post it here.
Posted on Sep 29, 2007
IrishDruid
  • 2712 Answers
SOURCE: Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Posted on Oct 23, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Posted on Nov 21, 2008
engrkoiled
  • 34 Answers
SOURCE: flashing led power button on deskjet d2460
try to check your cartridges. Pull it out one at a time then try to see it it stop blinking. Especially cartridges that was refilled. Improper refilling of cartridges causes them to stop responding to your printer and causes to malfunction. this was base from my experience.
Posted on Mar 26, 2009
wayneard
  • 1901 Answers
SOURCE: I can't find a power switch at all. How do I turn it off?
Sorry, no power switch! To remove power you need to remove the power cord. I know...dumb, huh?
If you have not been to this page it gives info on the Front Panel button and the Status lights.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl04300&locale=en_US
You will also note on this page that when doing a cold reset you must unplug the power cord and reconnect.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl03800
Thanks for using Fixya.
Posted on Jun 27, 2009
Who repair kodak printers
Just google that, I would think there are lots of online repair companies.
Sep 21, 2016 | Kodak ESP Office 2150 All-in-One Inkjet...
Why does the scanner keep turning off after 30 minutes with a red light? We have to keep manually turning it off and on.
Some kodak of the i2000 series abide by different energy conservation standards. You can increase both power off \ sleep settings to 240 (4 hours), maximum. Unfortunately when the newer energy conserv's go have to be power cycled to resurrect. I have a tiny text script I can send that will make the 2400 never turn off I'm just not around my PC right now. Stay tuned!
Oct 20, 2014 | Kodak i2400 - document scanner
Problem with kodak z650 camera wont stay on
Hello Francine, Sounds like internal fault, need to have service check,may be too costly to repair.
Best Regards, Russell
Jan 21, 2013 | Kodak EasyShare Z650 Digital Camera
Kodak z650 comes on fine but doesn't stay on-funny noise before it cuts off
Hello Donna, You camera is suffering from age, needs to be repaired or time to replace it. Sorry.
Nov 02, 2012 | Kodak EasyShare Z650 Digital Camera
Office hero 6.1 will not turn off or respond.
I had same problem - just contacted Kodak live chat, they talked me through a couple of fixes which didn't work, so they ordered me a free replacement. The printer was 9 months old.
Jul 04, 2012 | Kodak 5500 ALL-IN-ONE PRINTER
Wont stay on the blue light comes on then to set
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and charge them. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Dec 01, 2009 | Kodak EasyShare Z1275 Digital Camera
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
60 people viewed this question
jasbo
jasbo
