Question about Champion G5NG853S Household Juice Extractor
Motor will not run - Champion G5NG853S Household Juice Extractor
Motor runs and is seem like it has a clutch that is slipping. Tried the re-set button. The re-set button does not seem to engage anything. Took the 4 screws off the bottom but do not see anything that...
The white impeller that you attached the basket and blade to is
keyed to the motor shaft. There is a small shallow nut that you
can remove with a needle nose pliers and pull the impeller off
the shaft to see if it's seated properly or damaged. If damaged
talk Waring into selling you another at 1 800 492 7464.
Apr 03, 2011 | Acme 5001 Supreme Juicerator Juice...
WONT RUN
is it all put together? if if is not all put together properly it will not power up. if the whole thing is put back like the picture and it doesn't work perhaps it is your motor?
Jan 03, 2011 | Champion G5NG853S Household Juice...
Will not run
mine either, went to juice and the motor was running but not strong, then it just quick working...would love a solution as i love my juices! your help would be appreciated
Aug 06, 2010 | Jack Lalanne Power Juicer (Stainless...
Stuffed parsley into the juicer and the motor stopped
Push red reset button on bottom of juicer. The
juicer is not designed for leafy produce, only
apples, carrots, celery, etc.
Apr 22, 2010 | Acme 6001 Juice Extractor
Motor not running
The stainless bar has a safety cut off switch at both ends. You have to put it back the same way to make the outer switch work.
Jun 17, 2009 | Jack Lalanne Power Juicer 250 Watts
Breville JE95XL juicer
I used needle nose pliers, it took a bit of patience but I got the screws out. I think I might replace them with regular screws. My juicer does not run either. Let me know if you find the problem with yours.
Dec 26, 2008 | Breville JE95XL Juicer
Champion G5NG853S Household Juice Extractor Logo
43 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
