Question about Kenmore 85871 Electric Dryer
Kenmore electric dryer 87089601
Squeaking noise on start up
  • 146 Answers
SOURCE: Loud Squeaking Noise kenmore gas dryer 80 series
You need to change your drum rollers. To get to them you take the dryer apart from the front not the back. There are 2 screws where the filter goes in on top. Then pull the top toward you and up. Then remove the 2 - 5/16 inch screws on each side of the front panel about 2 to 3 inches down. Then pull the front up and out. Then you will see everything. Replace the belt, drum rollers, and idler making sure to oil each as you re-install them. Then put back together and your on your way.
Posted on Dec 21, 2007
kachbibi1
  • 979 Answers
SOURCE: Kenmore Electric Dryer 66812 clicking not starting
I hate to tell you this, but it is probably the timer. The good news is that it is easy to replace and you don't have to have a tech to do it.
Posted on Jan 14, 2009
  • 198 Answers
SOURCE: Kenmore dryer HE4 sounding like a boot is in it.
Check the drum rollers inside the cabinet, go to appliance guru and it will show you how to get to them.
Posted on Jan 18, 2009
  • 65 Answers
SOURCE: Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Posted on Jan 28, 2009
pride applia
  • 232 Answers
SOURCE: Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Posted on Jul 01, 2009
Dryer slow to start squeaks
The drum is belt driven, there is a belt tensioner on it too. You need to replace the belt.
Feb 25, 2015 | Kenmore Elite HE4 Electric Dryer
How do I fix my Kenmore electric dryer which is squeaking.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 22, 2011 | Kenmore 83142 Electric Dryer
Dryer is making a squeaking noise when it is drying?
It's either 2 things, a squeaking belt and/or the bearings in the electric motor.
Jan 08, 2011 | Kenmore Elite HE4 Electric Dryer
Loud squeaking noise with my dryer model # 100.77092600
heatman101
Dec 22, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore 70 Series dryer squeaks while tumbling - otherwise it works - what might be causing the squeak - a belt or loose screw?
heatman101
Dec 16, 2010 | Kenmore 64722 Electric Dryer
Kenmore electric dryer Model # 60622990 squeaks continually during operation
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 11, 2010 | Zanussi TC180W Electric Portable Dryer
Kenmore Oasis drum began screeching when i started the dryer this a.m. - no problem last night. Can i fix it?
heatman101
Sep 01, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
417.83142201 just replaced felt pads, upper and
try to lube the rollers on the back wall, where the drum mounts , sometimes the wheel bearings tend to make noise specially when dryer is overloaded and hot
Feb 05, 2010 | Kenmore 83142 Electric Dryer
My LG DLE2514W electric dryer starting making a squeaking noise at the end of a drying cycle last night. After letting it sit for over an hour, started the dryer back up and the squeaking noise came back...
heatman101
vciku
Jun 29, 2009 | LG DLE2514 Electric Dryer
Dryer will not work1
Squeaking noise often indicates problem with drive belt. If belt broke, drum will no longer rotate. Belt is similar to fan belts used in autos. Ck Sear's website for parts diagram of yr dryer. If it shows a drive belt, I would start there.
Jun 05, 2009 | Kenmore 659 Electric Dryer
Kenmore 85871 Electric Dryer Logo
20 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
