Question about Emerson LC320EM9 32 in. LCD HDTV
I have a split screen on my 32" emerson tv when I connected my DVD player (it is not a blue ray). How do I get rid of the split screen? Also on the scree is a triangle with the word PSCAN in it.
The DVD player is a Electrohome DVD & VCR player.
freetek
  • 5568 Answers
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
SOURCE: I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Posted on Jan 22, 2009
  • 56 Answers
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Posted on Feb 02, 2009
dsacco86
  • 1077 Answers
SOURCE: Can't see the top or bottom of screen on my emerson 32" Flat Scre
If it's like mine, there should be a screen mode button on your remote. Keep pressing it to change to different settings.
Posted on Feb 07, 2009
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
Feb 26, 2015 | Samsung DVD-V3500 DVD Player/VCR
When you chose the settings menu what do you chose to set the tv to hdmi to get the dvd/blue ray player to play
There are two HDMI inputs on your TV, so, depending on which input the DVD player is plugged into, HDMI 1 or 2 , that's the one you choose. The menu should list the inputs as HDMI 1 and HDMI 2.
May 19, 2014 | Emerson LC320EM9 32 in. LCD HDTV
My tv is coming up with a split screen when connecting DVD player
If it is a "3-D" DVD player, and your TV cannot handle "3-D" output, you get a "split-screen" (whole picture on left 50% of the screen, whole picture on right 50% of the screen).
Jan 01, 2014 | Sanyo Televison & Video
Dvd player is playing a vertical split screen
If the TV does the same with two different DVD players, it must be a menu setting on the TV. Look through the TV menu options.
Jul 24, 2013 | Panasonic DVD-RP56 DVD Player
Lost owners manual
Click here to download the user manual to your set.
Aug 24, 2012 | Emerson LC320EM9 32 in. LCD HDTV
Blu Ray showing "split screen/double
Did you check your settings on your tv and blu ray?
Jun 04, 2017 | Televison & Video
Memorex dvd player pscan split screen
I had the same problem with mine. I flipped the switch on the back and it worked instantly, hope yours does too.
Feb 26, 2009 | Memorex MVD2042 DVD Player
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Emerson LC320EM9 32 in. LCD HDTV Logo
136 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
