Question about Pool & Spa
What does L1 mean on my hot tub - Pool & Spa
Hot tub pump will not start back up after cleaning hot tub
When you say the pump won't start back up, do you mean the electrical side of things and there is just no power going to the pump. Or are you saying that the pump is on but not pumping water.
I am going to think you mean the pump is on but not moving water. This is common after you clean and drain your hot tub. You have what is referred to as an airlock in your hot tub line. It is easy to remove the airlock by simply opening one of the unions near the pump. This will allow the air to release and water flow to begin again.
Make sure also that you have cleaned the hot tub filters, if they are dirty and reduce water flow that could shutdown your hot tub pump as well.
If it is the electrical side of things make sure your GFCI has not tripped and maybe you just need to reset this. If it is anything further on the electrical side make sure you involve a professional.
  • open a union to release any airlocks.
  • clean your hot tub filters.
  • check to make sure your GFCI is not tripped.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
You may have to change your hot tub filters as well and can find an assortment of filters here. The filters should be changed yearly, and cleaned monthly.
Hot Tub Filters
Jan 30, 2016 | Pool & Spa
Balboa hot tub wiring diagram
CAUTION: Electrical work and repairs can be dangerous, especially around water. There is a risk of shock or electrocution, which could result in serious injury or death. We strongly advise that hot tub electrical wiring be referred to a licensed electrician. Local code requirements for wiring vary and may differ from the educational examples on this web site. The local code regulations must be followed, with permits and inspections obtained. The installer should read and follow the hot tub owner's manual and associated electrical component owner's manuals and instructions.
Try this link: file:///C:/Documents%20and%20Settings/Gil/My%20Documents/Troubleshooting%20&%20Service%20Manual%20230V.pdf
Jan 21, 2014 | Delta Tools & Hardware - Others
My gibson furnace geves the error L1 neutral polarity
This means the hot ( L1 ) and the neutral connections are reversed.check the 120 volt power to the furnace for the correct polarity also make sure there is a good ground connection. Hope this helps.
Dec 07, 2013 | Heating & Cooling
Wiring a single speed 230v 5hp ao smith pump: what wire goes to terminal B, L1, L2, A
L1 and L2 are the posts to hook up to, there is no polarity so either way works,
Oct 06, 2013 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
What does L1 mean?
Normally L1 is the line HOT feeder , in any appliance or equipment if you measure with Ground or Neutral, you will have 115Vca.
God bless you
Sep 22, 2012 | Washing Machines
What does L1 error code mean on an Electrolux dishwasher
The only solution I can come up with for this one is that L1 is a Leak Detector problem-When water is detected under the tub. I spent an hour researching this issue. I've never come across this one before.
May 11, 2012 | Electrolux Dishwashers
What mean L1 and L2 for the connexion of the heater
L1 Means Line Voltage L2 means Line Voltage
If you have 220 as your supply voltage than one side would go to L1 and the other to L2.
Hope this helps if you still have problems post another post along with more information as to what voltage you have.
Jan 02, 2011 | Dimplex EF621C Electric Wall Mounted Panel...
On the fp3222-11 well pump it said it needs 230v, is that on both hot leads, that each lead has to have 230v reading?
That means when you check your supply voltage it will be 230V from hot to hot.(L1-to L2) You would still read 115V to neutral on each leg.
Aug 17, 2010 | Flotec 075 HP Submersible Well Pump 3Wire...
Have a tork time switch (mechanical) and have question on how to ground it? Also help in understanding their wiring diagram on box cover..
They are simply grounded by a screw inside usually on the metal box... it will be identified by its green color...simply connect the ground wire to that green screw...
L1 will be the black or "hot" wire and L2 or N will be the white wire...
L1 will feed through and be the "hot" coming out switched...normally open is when the switch needs to make to send power out and normally closed means that when the switch makes it will stop the power going out...
heatman101
Aug 07, 2010 | Hardware & Accessories
Pool & Spa Logo
37 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
