Question about Dishwashers
I have a Bosch dishwasher type S9G1B the display led has stopped working suddenley and it starts to fill then stops after 30 seconds can you help
Its Bosch Exxcel auto option The diplay was working but the machine would nit start the timer just ran down. there is now no display and the machine pumps in water for around 30 seconds then stops and will not go any further
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
Posted on Aug 20, 2008
SOURCE: Bosch Exxcel Auto option
You will find the float s/w under the d/washer not inside,you may have a leak which has activated the float?
Posted on Oct 27, 2008
57 varieties
  • 1653 Answers
SOURCE: I am looking for the operation manual for my
You can download it from the following Bosch Support Link
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=ngfv1dacdcso0mchdb---alz&UMOBID=ngfv1ekcdcso0mchdb---alz
Posted on Oct 09, 2009
Bosch dishwasher stopped working after few minutes. And LED displayed E:24. What is the problem?
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Sep 05, 2016 | Bosch Dishwashers
Bosch S9G1B dishwasher doesn't fill with water
The valve will not energize if the float is up at the limit. Sometimes a bit of soapscum can leave the float in the up position. When this happens no water is allowed into the chamber. Move the float up and down and clean the travel using a bleach spray.
Jan 18, 2015 | Bosch Dishwashers
Hobart dishwasher LXIH starts filling and stops after 5 seconds or so
Hobart is probably the most user friendly manufacturer out there. Their service manuals are great. Try this.... Good luck Manuals Support
Feb 17, 2014 | Hobart Dishwashers
Bosch dishwasher starts, pumps, stops and says it's clean
We have the exact same problem with our Bosch SHE5AL06UC/05 dishwasher. Works great when it works, but we are increasingly having a hard time getting the wash cycle to start.
Apr 13, 2012 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
How to run a diagnostic test:
  1. Unplug power cord, then wait 30 seconds.
  2. After plugging in, follow these instructions...
To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
  • "t01"
    Model ID
    Verifies (or sets on new board) the proper Model id
  • "t02"
    Error Codes
    Lists up to 10 control-detected problems
  • "t03"
    Software ID
    Verifies using latest Control-eePROM-lnverter software
  • "t04"
    Exercise lCD/lEDs
    Verifies that all the displays and buttons work
  • "tOS"
    Pump Test
    Tests drain-out pump
  • "t06"
    Pressure Switch Test
    Fills to all 3 levels, then pumps out water
  • "tOT'
    ThermistorlHeater Test
    Verifies that both the Thermistor and Heater work
  • "t10"
    Tumble Test
    Verifies Washer Tumbles (I.e. Wash cycle)
  • "t11"
    Spin Test
    Verifies Washer spins
  • "t12"
    Dispenser Test
    Verifies Dispenser fill works-for all four fill modes
  • "t13"
    EOl Test
    Performs End-of-Line test sequence
Button Commands (based upon test mode)
t01 prerequisites: none
Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
Power Returns to "t01"
t02 prerequisites: none
Start Displays most recent error code (EOO=none)
Start Displays previous error code (up to previous 10)
Hold start Clear all error codes (and then displays EOO)
Power Returns to "102"
t03 prerequisites: none
Start Alternate "cod" and Control Software version
Start Alternate "EE" and eePROM version
Start Alternale "Inv" and Inverter Software version
Power Returns to "103"
t04 prerequisites: none
Start loops on lighting lED's, LCD and cycle ids
Any button Beeps when depressed
Power Returns to "t04"
tOS prerequisites: none
Start Displays "P" and pump for 60 seconds
Power Returns to "t05"
t06 prerequisites: none
Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
Start Fill, when reaches Main level-displays "nl"
Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
Power Returns to "t06"
t07 prerequisites: Main level pressure switch must work
Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
Power Pumps out water and returns to ''t07''
t10 prerequisites: none
Start Displays "It" and tumbles tub alternating the direction every 5 seconds
Power Stops tumbling and returns to "t10"
t11 prerequisites: none
Start Spins to 400 RPM displaying increasing RPM
Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
Power Stops spinning and returns to "t11" when stops
t12 prerequisites: none
Start Displays "pdt" and fills via pre-wash chamber
Start Displays "ddt" and fills via main wash chamber
Start Displays "bdl" and fills via bleach chamber
Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
Power Pumps out water and returns to "t12"
t13 prerequisites: none
Start Starts EOl test sequence (NOT used in Repair)
Power Returns to ''t13''
Once you have the diagnostic codes, check this post for the meaning of the codes:
http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Jun 25, 2011 | General Electric WCVH6800J Front Load...
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Long cycle times
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. About the led: If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Dec 30, 2005 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
Owen Barnes
