Question about Canon PowerShot G9 Digital Camera
Stuck/sticky option whell
I can barely tun the option wheel on the back of the Canon G9. Great camera for 1 1/2 years. Was in windy environment this summer with some blowing sand but still functioned fine over Christmas. Now try to set manual distance or change shutter speeds and it's almost impossible to turn the wheel.
Ideas?
Thanks
RT Ryan
  • rtryan218 Jan 14, 2009
    I did try a little lubricant both around the outside of the wheel and the inside but no success. Without really exerting some pressure on the wheel it can't be moved and certainly not with just the right thumb while holding the grip and looking through the viewfinder or at the screen. The function center section (MF, mode, macro etc.) still works easily and fine but the wheel will not turn without quite an effort.
    Sergeant:
  • 233 Answers
I had this problem as well, I used a q-tip and rubbing alcohol to fix mine. I removed the batteries and used the q-tip to drop a few drops of alcohol into the wheel, and worked it back and forth befor the alcohol evaporated.. it worked for me.
Posted on Jan 14, 2009
  • 82 Answers
Thanks for using Fixya! I would try using dry lubricant this works well in situations that needs lube without the mess of grease and oils.
Posted on Jan 13, 2009
My Cannon Powershot G9 camera is having the following problems: 1) I can not change the function; is is stuck on record. Pushing click button does not stop recording, 2) The battery seems to be draining...
That's a typical power problem in this camera, it probably has a short from some loose screws inside. This is a common thing on your model, you can just have it fixed and the screws inside the camera corrected so they can't come loose on their own again. The site that does the service on the Canon Powershots that is wonderful is: www.camerasandparts.com They only work on the Canons and they are terrific for service on these. They don't charge much at all and they include the correction to the screws that come loose on all G9's when they service them. Good luck having it fixed up, that site is where many people go for help with this power problem on the G9's
Aug 07, 2011 | Canon PowerShot G9 Digital Camera
Canon g9 flickers for a second when turned on, then nothing else appears or happens. Any suggestions?
Camera most likely has a short inside, it happens from loose screws on these cameras. You'll need to get it fixed and it's good to do the correction to the screws inside once repaired. The shop that is great for these is: www.camerasandparts.com They only work on Canon Powershot's and they are wonderful for help with these. For $89, they do the repair, the service on the camera and the internal no power correction at the same time, they even cover the cost of the shipping back. They know these cameras well, if you need help with it, they're great for these cameras. Good luck with the problem on yours.
Jul 11, 2011 | Canon PowerShot G9 Digital Camera
My G9 wont open the battery is charged
When my former wife arrived from a European trip, she was very upset because suddenly the Canon G9 I had lent her wouldn't open. It was right before Christmas too. I immediately went on line and found Cameras and Parts which was highly recommended by others. After having an unproductive conversation with Canon in which they claimed their was not a general problem with the G9, I contacted Cameras and Parts. I'm happy to report that the camera was fixed in no time and cost about half of what Canon wanted - plus it was refurbished and works great. So you might try Cameras and Parts.
Jan 14, 2011 | Canon PowerShot G9 Digital Camera
My canon g9 will not power even with newly charge battery
You can go to this site: www.camerasandparts.com They're excellent for the Canon Powershot cameras.
Dec 29, 2010 | Canon PowerShot G9 Digital Camera
Canon G9 will not power up
Yes there are a lot of good shops, one place that is great for these is: www.camerasandparts.com since they not only fix the problem but they include the fix automatically for that common screw problem on the G7 and the G9 models. They have the fix for this on their site and it's under $100 which cover everything, the service for the camera, a warranty on the whole camera, and shipping back. They do excellent quality repairs and powershots are all they work on. Hoping that helps.
Bill
Aug 06, 2010 | Canon PowerShot G9 Digital Camera
My cannon g9 camera stopped working. the lens is stuck open and it won't turn on. Any suggestions?
Common no power problem on the G9, you just need to get it serviced. There's a great site that only services the Powershots, they're amazing when it comes to servicing these models. On the G9, they do a fix in the camera so the short never happens again which is great, plus they service up the rest of the camera. They don't charge much and they're amazing if you need help with a Powershot. Try them, their site is: camerasandparts.com Good luck, that's the best place if you need help with a Powershot problem.
Jun 15, 2010 | Canon PowerShot G9 Digital Camera
Will not turn on, and battery is good
Lots of people go through this on the G9. Certain screws inside often come loose inside and short out the camera leaving it with no power. A great place to service these is: www.camerasandparts.com All they work on are the Canon Powershots and they do excellent work. It's $89 through them for the parts / labor to fix this, and they service up the camera at the same time when it's being repaired, plus they cover the shipping going back. On the G9's, they also do some correction inside the camera so that the screws don't come loose again inside and cause this problem. If you need to have it fixed, they're the place for this G9 problem.
Jan 07, 2010 | Canon PowerShot G9 Digital Camera
VIDEO STARTED PLAYING BACK ONLY IN HIGH SPEED W/O VOLUME,,,,,,,CHANGED SPEED OUT OF NOWHERE.....PLZ HELP! I'M USING CANON G9
I EASILY FIX'D THIS PROBLEM & FOUND OUT I CAN DO SOOOOO MUCH WITH SHOOTING VIDEO'S! I DID A GOOGLE SEARCH & CAME ACROSS THIS ADVICE.......TURN THE TOP DIAL ONTO VIDEO ON TOP OF CAMERA. THEN TURN DIAL ON RIGHT SIDE & YOU WILL SEE DIFFERENT SCREENS SUCH AS BLK & WHITE, VIVID COLORS, FAST OR SLOW SPEED; I TURNED MINE TO AUTO & PRESSED FUNC BUTTON IN CENTER OF WHEEL & I WAS BACK TO SHOOTING IN NO TIME........HOPE THIS HELPS!!
Jun 20, 2009 | Canon PowerShot G9 Digital Camera
Downloading from the Canon G9.
You might want to pickup a Lensmate pen cleaner to clean your optics. There is a micro one that works great for this size type camera.
Jul 01, 2008 | Canon PowerShot G9 Digital Camera
Lens error on brand new G9
i got the exactly same problem!!
i bought it on 16th/Feb, next day,17/Feb not more than 20 pictures i took, the issue comes (lens won't action while shift the zoom lever, but it's working ok while switch on and off the camera)
so i bing it to the shop with my angry, they just said to me that you must dropped the camera.
--but i sware i didn't !!!
now they took the camera to Canon base for the exam...
Jan 20, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Canon PowerShot G9 Digital Camera Logo
24 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
