Question about Konica Minolta bizhub C351 All-In-One Laser Printer
What do the numbers on the Unit Life Indicator consumables list mean? Is the number good or bad news, etc.?
For instance, the Magenta toner says 2314. Is that copies to go before running out or is that what has been copied on it? Fusing Unit says 271453 what does that mean? Nothing in the manual.
5 Suggested Answers
  • 12 Answers
SOURCE: Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Posted on Aug 01, 2008
Junoon007
  • 1011 Answers
SOURCE: Bizhub C351 Magenta Image Unit Problem
Sir,
The print head assembly has failed. Replace the print head assembly
Posted on Jan 15, 2009
  • 518 Answers
SOURCE: the screen says YM toner low. Does this mean
the lazer unit needs recharging
Posted on Jul 06, 2010
  • 6771 Answers
SOURCE: Good Afternoon, our printer
If the machine is only two months old it is time to contact the company you purchased it from. There is clearly a problem with the toner, it is clogging and not evenly applying the colors and it is streaking. From your description the toner is defective and not working correctly and probably needs to be replaced, this should be covered under your warranty and the company's responsibility that you bought it from.
Posted on Jan 24, 2011
Xerox phaser 6360 smearing magenta toner only
that's the developer assembly that has gone bad. If you're using 3rd party toner it wears down a lot quicker. You'll need to replace the magenta developer unit, part number is 848K03850.
http://www.iteminconline.com/848k03850_848k03850-xerox-6360-developer-assembly-magenta-oem-new-genuine.htm
Feb 09, 2016 | Xerox Office Equipment & Supplies
Magenta cart. wont print
The problem is most likely a bad Image Unit.
Xerox guarantees their supplies to be free from defects as long as their is a life percentage left and will replace it for free.
Take it back to the store you purchased it from and ask for a replacement, or have them request a replacement for you.
If the magenta fails (within 100 pages) after you replace the Image Unit, then your toner dispense mechanism is failing for the magenta toner, and either a dispense motor will need replaced, or the toner auger will need to be unclogged or replaced.
Jan 28, 2014 | Xerox Phaser 6360 Laser Printer
How can i settle the problem of magenta developer finishing so fast. Magenter developer for Konica Minolta Bizhub C550 is getting finished so fast.
If the message Change Imaging Unit Magenta displayed refer to imaging unit with contents a developer.The Imaging unit life is 80.000 copies.
The imaging units located after front door when is located the waste toner box.
If the message M toner end/change the M toner displayed refer to toner cartridge
The toner cartridge life 15.000 copies 5% saturation.In full color mode the color saturation is 80% and the color toner life is 6.000-8.000 copies.
I think your problems is a toner not the developer.
Apr 11, 2013 | Konica Minolta Bizhub C550
Prints with magenta wide lines
Your magenta imaging unit life finish,need must be change the imaging unit.
Feb 28, 2013 | Canon LBP5960 A3 Colour Laser & Free Toner...
How to clean the magenta toner out of the drum unit
Change the magenta image unit,your image unit life end,
Feb 28, 2013 | Canon Color ImageRunner LBP5970 Laser...
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
I am getting a code of E000751-0302, not all the time but is becoming more frequent. I have the codes for the 3200 but this one must be 3220 only as it is not listed. Thanks, Tom
E751 (0302) code is not found in the Service Manual. This code is addressed in Tech Pub TP03 125. The code refers to a memory writing error in the magenta drum unit. Check or replace the magenta drum unit or the Memory board (Memory Board part number is FG3-2345-000.
E751 The connection of the drum unit /toner container is faulty. The mark x indicates color [Y=1, M=2, C=3, K=4]. 000x The connection of the drum unit (at the printer side) is faulty. 100x The connection of the toner container (at the printer side) is faulty. 010x Built-in memory writing error in the drum unit. 110x Built-in memory writing error in the toner container. 020x Built-in memory data error in the drum unit. 120x Built-in memory data error in the toner container. 030x Built-in memory writing error in the drum unit (When the number of retry exceeds the specified value) 130x Built-in memory writing error in the toner container (When the number of retry exceeds the specified value).
Sep 30, 2009 | Canon Office Equipment & Supplies
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Error message imaging unit is out
Hi rmcday: Here your problem. The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following: ■ An OPC Drum ■ Waste Toner Assembly ■ Charge Roller Assembly 9.0 Consumables, Routine Maintenance Items and Options Item Life based on 5% coverage Part No. Replaceable by Black Standard Toner Cartridge Black High capacity 3,000 7,000 106R00679 106R00684 User replaceable Cyan Standard Toner Cartridge Cyan High capacity 2,000 5,000 106R00676 106R00680 User replaceable Yellow Standard Toner Cartridge Yellow High capacity 2,000 5,000 106R00678 106R00682 User replaceable Magenta Standard Toner Cartridge Magenta High capacity 2,000 5,000 106R00677 106R00681 User replaceable Imaging Unit 50,000 images 108R00593 User replaceable Transfer Belt 50,000 images 108R00594 User replaceable 500-Sheet Feeder N/A 119650600 Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable. Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced. Hope this helps
Jun 10, 2009 | Xerox Phaser 6120/YN Laser Printer
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
88 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
