Question about Transcend StoreJet 25 750GB USB Hard Drive
My transcend 750 gb storejet does not copy
As soon as i plug in i have to copy-paste the file. Or else it does not copy and it gets hanged. Please help me!!!!
  • Transcend Master
  • 27,725 Answers
Click start control panel Administrative tools Computer Management Disk Management right click on your drive select properties click tools you should see click check now click start two boxes Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not do anything while the chkdsk utility is in progress any input may damage this drive. You might get best results ticking in one box the returning after it has finished then ticking the other box it might take some time depending on the of your disk but be patient. Hope it helps.
Posted on Dec 10, 2012
SOURCE: Transcend external hard drive not working.
Contact Transcend Support:
support@transcendusa.com
Posted on Jun 09, 2008
pankaj_dic
  • 1250 Answers
SOURCE: detection problem
check it on other usb ports, also replace the usb cable
Posted on Oct 07, 2008
saqeb
  • 47 Answers
SOURCE: transcend storejet 25 mobile 160gb show error " usb device not re
Most probably your drive has been damaged. Try it on another system and if fails, no way
Posted on Jan 28, 2009
mayur_best
  • 25 Answers
SOURCE: Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Posted on Jan 29, 2009
Geekman
  • 32281 Answers
SOURCE: USB 16 GB transcend says disc is write protected!!
You should try to delete the partition in the Transcend memory stick and creat a new partition. You should copy any files that you need off this memory device before you re-partition it because you will lose all the data that is stored on the device.
Go to the Control Panel - Administrative Tools - Computer Management - Disk Magament.
Scroll down until you see your removeable device the 16Gb memory device, click once on this, It may not show it as Healthy.
Right click in this disk (make sure you do not select the C drive) and click on Delete Partition to remove the partition.
Right click on this unpartition drive and Create a partition.
You may not have to format this partition, it should now show this as a healthy drive.
Exit out of Disk/computer Management and Control Panel.
The USB drive should now function normally.
Posted on Mar 07, 2009
My external hdd transcend 320 gb storejet is very slow while copying file to or from the hd and the blue LED keeps on blinking what might be the problem??
Well u may have it plugged in USB slot but needs to be USB 2.0 .if in regular. USB..will run slow...also external he'd when u not using. It unplug. From USB and AC plug...not good to just let run..they will were out..defrGment hdd to.good luck
Dec 21, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
My transcend flash drive storage size has been reduced from 1gb to half of it. Please help
Please move/copy your current files to other storage, then format your Transcend storeJet USB. You should get a better space now. This happen because you have temporary files and space engage for caches or hidden files on transcend USB.
Good luck.
Aug 08, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I am having a external 250 Gb transcend store jet Harddisk..it was working fine but after 15 minutes....suddenly it is saying that write protected ,,,i am not able to copy anything to harddisk and not able...
I HAVE THESAME PROBLEM WITH Transcend StoreJet 2.5 120 GB USB 2.0 Hard Drive ON MY VISTA 7..WHY THERE ARE no any hints or answers here ? so we can get help? thanks
Jul 29, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My mac is reading my transcend storejet 25 mobile 320gb, but i cant copy files from my mac unto it
Hello Kinoshia,
It seems that Transcend external hard drive have different file system. This is because the Mac machine is not able to transfer the files on to external hard drive. Please format the Transcend external hard drive from Mac machine and then hard drive is ready to accept the data from Mac machine. The drive either has to be formatted for Mac( HFS & HFS+) or FAT32 partitions. If you want to use
Transcend external hard drive for both Windows and Macs than format the drive to be FAT32.
Jun 05, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I can not copy more that 2 GB toTranscend StoreJet 320 GB? Why?
This is most likely because your hard disk is formatted using FAT32 which has a limitation of 2GB file size. Backup your data in another location and format the disk to NTFS and you should be able to copy that big file.
Mar 08, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I have my Transcend Storejet 320GB USB HDD. On my laptop it detect the drive but it not showing any data inside and hang the PC. Is there any utilities to get my data recovery?
In this case you should use data recovery software to try recovering the files and data, provided those lost data are not fully overwrtten.
Be careful: Before your files are recovered, do not attempt to save more files to the HDD in case the original files are overwritten.
Sep 14, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Setup
recently i bought Transcend Jetflash 8GB pendrive. when i am copying mp3 and other vedio files, it is showing some different files with file extension. plz suggest me how to solve this problem
Jun 02, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend StoreJet 25 750GB USB Hard Drive Logo
104 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
