The washing machine wont start program
Error code H20 appeared. Checked the water pressure is OK and cleaned the water filter
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 10, 2012
  • Neil Dec 10, 2012
    Hotpoint WMF720 Aquarius. The machine is only 2 years old as well.
  • Richard Roth
    Richard Roth Dec 10, 2012
    H20 - Check tap and pressure of incoming water.
  • 1294 Answers
SOURCE: machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Posted on Sep 03, 2007
jason0110
  • 66 Answers
SOURCE: error code h20
hi sounds like a faulty fill valve easy fix
Posted on Sep 21, 2008
barkencoa
  • 3463 Answers
SOURCE: ERROR H20 STOPS PROGRAM DUE TO LIMITED WATER...WHAT CAN I DO?
The fact that you have 240V to the valve does not prove that the valve is o/k. Determine which is the live wire, and leave connected to valve coil.
You need to remove the neutral wire from the valve, and test with your meter that as well as having 240V going in, you have 240V coming out on the other terminal, if you have not , then you have a faulty valve..Simply replace it.
I assume that you have a neutral feed to the valve, because if you have not, then the fault is probably in the pcb board.
The coils on these valves often go open circuit.
Plz rate my solution.
Thanks.
Posted on Dec 22, 2008
  • 13 Answers
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Posted on Apr 11, 2009
  • 35 Answers
SOURCE: washing machine not draining the water
the weater pump is bad replace....
Posted on Apr 13, 2010
My Indesit 7105 has flashing H20 lights, have checked but no blockages. It fills and drains fine, It wont agitate though, any ideas?
The machine does not fill with water or 'H20' flashes in the display.
The water inlet hose is kinked. • The water inlet hose is not connected to the water supply. • The water pressure is too low. • The water tap has not been turned on to allow water to flow into the machine. • There is no water supply to the house. • The inlet valve filter is blocked. • The START/PAUSE button has not been pressed.
Faulty pressure switch machine thinks there is no water in the machine.
Apr 01, 2017 | Indesit Washing Machines
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarious WF630 error code H20. It will fill and wash with both hot and cold water but when it gets to rinse and spin the error code flashes. It will however spin if i manually change the...
H20 does in fact indicate a problem with the incoming water supply.
Check the inlet hoses/s to make sure they are not kinked or restricted in anyway, more so when the washer is pushed back.#
Make sure tap/s are fully turned on, make sure you have good water pressure.
It would also be a good idea to check the gauze filters in the inlet to the valve/s.
Feb 08, 2010 | Washing Machines
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code H20...My washing machine, a hotpoint wt740 is showing the warning light H20...does anybody know what this means? thanks
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments if further you have the same problem or you need more help or information........
Good Luck!!
Thanks
Dec 24, 2009 | Washing Machines
H20 ERROR
This error means - Problem is in the inlet valve.
Your inlet valve at behind top of machine is defective or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem then you need to change inlet valve.
Good Luck!!
Thanks
Jul 24, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
H20 error
Hello
I used to get this when i lived with my mum & dad and i can honestly say that it was the water pressure with this machine only a small drop in pressure makes the H20 error code appear you can always add additional water when it comes on so that the cycle can continue. You could find out from your water board if the drop in pressure is a leak in your area?
I hope this helps i had to persist with this problem for 18 months untill a leak around the corner was eventually found and fixed.
Regards
Wendy
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Thanks.
Dec 22, 2008 | Hotpoint Ultima WF860 Front Load Washer
H20
According to the Hotpoint error code list H20 indicates to check taps and pressure of incoming water..
So make sure you have adequate pressure of water at the valves, low hot water pressure can cause problems..
Also what I would do would be to check the filter located in the sump hose at the rear of the m/c,\this can leade to a sticking water level s/w..
Hope this helps.
Plz leave feedback.
Thanks.
Dec 13, 2008 | Hotpoint Ultima WD72 Front Load...
Error code h20
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
