Question about ASUS (F50SV-A1) PC Notebook
Notebook woks on battery but does not on power supply
The notebook is working using the battery and does not work using the power supply
    Novelist:
    Champion:
  • 233 Answers
Hello. It sounds like either...
1. Your Asus power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Posted on Dec 13, 2012
3 Suggested Answers
sys_admin
  • 829 Answers
SOURCE: use of usb ports shuts down notebook
Is there any data in the USB , I suppose it can be a virus , can you Format the USB stick and then insert to the laptop.
Posted on Dec 15, 2008
SOURCE: my notebook is not turning on,how do i know if its the battery
When you plug in the power cord is there anylights whatsoever on the laptop, where the plug goes in or on the AC Adapter ofthe power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Posted on Mar 31, 2012
My notebook shows no sign of power
Remove battery turn the notebook on, does it works?
press the battery back in place, is there any lock on backside op the notebook?
is there any signs of charging? flashing led or so?
if not the internal plug to the power supply could be damaged.
Mar 24, 2016 | ASUS X200CA Black 11.6" Notebook 1.5 GHz...
It will not power up battery or ac current. Installed battery 4 months ago it worked as long as battery had power.
You should replace your power supply. If it is possible, try with another power supply or try your power supply in another computer. If the power supply works well with another computer, it has to be a defective motherboard or power board on your notebook.
Oct 31, 2011 | Dell Latitude D600 Notebook
Toshiba SATELLITE A205-S4577 CORE 2 DUO INTEL. When conected to the external power supply the notebook suddenly interrupts its functioning and it is necessary to do a hard power off, becouse nothing more...
- possible problem with the AC power supply
- try using a different AC adapter. if issue persist try flashing the BIOS. if issue still persist then have the motherboard checked out.
Mar 29, 2011 | Toshiba A205-S4577 Notebook
I have a fujitsu notebook model lbs6120-aa029e0b0. At first the notebook would start but not recognise the hard drive. when turning it on at other times it would work normally then freeze. Now the...
If the notebook is not working at all now, you have to test the power supply to see if it is providing enough power to run the system. I would try to put the battery back on, let it charge for at least 12 hours, then try to turn on the system with the battery still installed on the machine. That way we can eliminate whether the power supply has sufficient voltage carrying capacity to operate the system.
If that doesnt work, then its time to call Fujitsu.
Aug 02, 2010 | Fujitsu LifeBook E8010 Notebook
I plug in the power supply the notebook doesnt power up but the green light on the supplier goes off?
Unplug the notebook, take out the battery.
Hold down the power button for 10 seconds
Now replug in your notebook
If it powers on, then the unit suffered a minor surge and you should from this point use a surge protector from now on.
If it does not power on, then the unit suffered a severe power surge and now the motherboard is blown and needs replacing or buy a new notebook.
Mar 16, 2010 | Dell Latitude D600 Notebook
D505 not charging battery, was working when plugged in - now won't even come on even when plugged in. I have replaced the battery and also the power supply - help.
1. Try using only the power supply.
2. If it won't turn on, unplug power supply then use just the battery.
3. If these two steps doesn't work since you've already replace the battery and the power supply.
You'll need to replace motherboard.
Jan 03, 2010 | Dell Latitude D505 Notebook
My v2000 will not come on at all? I have it plugged in with the adapter and it's like there is no power to it at all?
check power supply adaptor and batteries if they are supplying enough power, if you can borrow a power adaptor and spare battery try replacing them with one your notebook has.
if it works then your adaptor and batter are out, normaly if the adaptor stops working the battery would have died down too as you would have not noted till the notebook totally died down.
Dec 07, 2009 | HP Compaq Presario V2000 Notebook
Acer aspire 5552nwxmi notebook can't power on.
Unplug the battery and power supply from the laptop, then press and hold the power button for 25sec(No battert and power supply), then connect the cable back to laptop, then try to turn on the computer, if its turning on hten connect battery back to laptop...
Nov 24, 2009 | Acer Computers & Internet
Battery charger not working. Power adapter checks out ok. Laptop operates on battery only. 7325gz.
if it is not charging the battery will go dead.soo recharge it if it doesnt work then it could possibly be your charger.but alot of times the soldier on the input plug becomes loosened and doesnt get a connection. how did u check the chager
Oct 10, 2009 | Gateway 7325GZ Notebook
Notebook cannot power up
Any lights on the A/C power adapter ?? If not, then the power adapter is faulty. If the adapter is OK, the power connector on your Lifebook is faulty. Good luck
Jun 21, 2009 | Fujitsu Siemens LifeBook E4010 Notebook
ASUS (F50SV-A1) PC Notebook Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
