Question about Nikon Coolpix 4500 Digital Camera
"memory card is write protected"?? but it's not the memory card!
Nikon coolpix S51 says memory card is write protected. I have tried other memory cards and none of them are locked. Seems to be the camera. What do I do?
  • Anonymous Mar 14, 2009
    Exact same problem with this camera. Help!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
It's not the camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
2 Suggested Answers
praky16
  • 744 Answers
SOURCE: nikon coolpix s51 digtal camera memory card says can not be used?
hi..
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
You need to unlock the card itself. Take it out and look for a tab on the left. It should be pushed up.
thank u
rate me
Posted on Jul 22, 2009
What is write protected in memory card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 21, 2013 | Nikon COOLPIX S51 Digital Camera
Camera says memory card is write protected. How can I delete pictures on the card and take new ones?
write protection lock is turned on,, turn it off this maybe 1. a switch located in the camera 2. on off option in the camera menu else plug the camera to memory card reader to delete or format the chip :)
Dec 15, 2010 | Nikon COOLPIX S51 Digital Camera
My nikon coolpix s51 show message memory card is
For the message that show's on your camera here's is what your need to do. 1. Remove the memory card and check for the physical lock toggle.
2. Toggle the lock on and off.
3. Try blowing on the memory card and the memory card port so it will be cleaned somehow. here is the picture of the lock toggle of the SD memory card 919a7e0.png
Apr 13, 2010 | Nikon COOLPIX S51 Digital Camera
I have a Nikon Coolpix s51 but my screen is cracked. I am trying to transfer the photos from my memory card and camera to my computer, but i am having trouble figuring out how to do that???
At this point, I would remove the card from the camera. If you don't already have a card reader, invest in one. Connect the card reader to the computer, then plug the card into the reader. You can use Nikon Transfer ( http://support.nikontech.com/app/answers/detail/a_id/61 ) or the operating system's drag&drop to transfer the pictures to your computer.
If you have pictures stored in the camera's internal memory and the screen is at least partially legible, you can try to select "Copy" from the Setup menu to transfer pictures from the internal memory to the memory card before you follow the suggestions in the first paragraph.
Feb 03, 2010 | Nikon COOLPIX S51 Digital Camera
Nikon coolpix s51 digtal camera memory card says can not be used?
hi..
thank u
rate me
Jul 22, 2009 | Nikon Coolpix S51c Digital Camera
Memory card write protected
Check the side of the memory card. Some of them have a little switch that turns on/off write protection. If there is no switch, you can try to format it in the computer first, then put it in the camera and format it again.
Jul 11, 2009 | Nikon COOLPIX S51 Digital Camera
Memory Card is write protected
Does your MMC have a Lock/Unlock swap features? if it does. Then Unlock it. Or, you might want to format it.
Jun 14, 2009 | Nikon COOLPIX S51 Digital Camera
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Mar 31, 2009 | Nikon COOLPIX S51 Digital Camera
''Memory card is write protected''
Remove the SD memory card from the camera and move the small switch on the side to the unlock position. That should solve the problem.
Mar 16, 2009 | Nikon COOLPIX S51 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
823 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
