Question about Gaggia Syncrony Espresso Machine
How do i open a gaggia syncrony
Hi i need to access the machine to replace a microswitch for the brewhead ,any ideas as i dont want to undo what doesn't need undoing
  • 109 Answers
SOURCE: gaggia syncrony manual
http://www.partsguru.com/GaggiaSyncronyCompactDigitalEspresso.html
Have a look at this site it should have what you need.
Posted on Jan 31, 2008
EsWorld
  • 1618 Answers
SOURCE: Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
Posted on May 24, 2009
EsWorld
  • 1618 Answers
SOURCE: GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Posted on Jun 09, 2009
  • 80 Answers
SOURCE: Gaggia Syncrony is stuck on "Ventilate
check flowmetar,i had same problem.
Posted on Aug 02, 2009
SOURCE: low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Posted on Sep 28, 2009
My Gaggia syncrony digital has just stopped working....the coffeee is still being ground but there is no coffeee coming out....no water seems to be getting through. Any ideas?
There is one of 2 things going on either the machine needs to be descaled and or the brew unit screen is blocked. Remove the brew unit from machine and check screen below the red o-ring.
Aug 04, 2011 | Gaggia Syncrony Compact Coffee...
Gaggia syncrony digital DECALCIFY, I done the prosess but i have the worning about DECALCIFY
You must use the correct tablets for this, gaggia make special decalcifying tablets.
The machine must be cold when running the program.
It takes about an hour to run the solution through the machine.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Gaggia Syncrony Compact Digital Espresso...
Gaggia Syncrony "ventilate"
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 04, 2010 | Gaggia Syncrony Espresso Machine
I have a Gaggia Digital Syncrony. The machine
Hi
You could have a micro switch in the doser that is going bad and needs to be replaced. They are a special micro switch that is very sensitive and can get stuck with a little coffee dust inside the switch.
Mar 10, 2010 | Gaggia Syncrony Compact Digital Espresso...
Syncrony digital gaggia coffee maker leakage+ventilate message
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Feb 02, 2010 | Gaggia Syncrony Compact Coffee...
Hi! Can you help me with a Gaggia Syncrony Compact Digital please?
gaggia syncrony ,The unit that goes into the side of the machine is jammed , can you help ?
Jan 17, 2009 | Gaggia Syncrony Compact Digital Espresso...
Gaggia Syncrony Compact Rote LED 28 blinkt
Try to prime your machine, if you only get a half cup of water then you have to replace the flow meter in the machine.
Jul 20, 2008 | Gaggia Syncrony Espresso Machine
Gaggia Syncrony Espresso Machine Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
